posted by Luda315 on Jun 15, 2008
The convergence went on my tv. I tried to reset it but it only moves vertically. There is also a permanent swirl at the top of the tv. What do i need to do to fix it.. Please help. www.luda315@aol.com or call me at 646-416-2762
thanks
Luis Cruz
Comment by Luda315, posted on Jul 12, 2008
i switched the ic's and the ohm and now it doesn't go on. I hear like a hearbeat like pattern and then it stops.. What did I do wrong
Best Solution
posted on Jun 15, 2008
Luis. You need to replace both the convergence ICs which are STK392-110 and possibly the 1.8 ohm 1 watt resistor you can get replacement ICs and resistors at the following link and they provide free installation instructions with pics so you can do the job yourself which is very easy on your model set.
http://servicemanuals.vstore.ca/
Comment by Slinteriors, posted on Jul 12, 2008
Solder shorts if it sounds lika a thumping in the speakers. you either have a short between a couple pins or a couple of pins arent connecting thats the only thing that will cause the thumping after changing ICs.
Rating Locked! (?) Luda315 has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for JVC AV-48WP30 48 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
JVC AV-48WP30 48 in. Rear Projection...
green convergence problem
ok i have a jvc av-48wp30, it... Answer This...
green problem
green problem
DIFFERENT convergence problem
clean behind screen
clean behind screen
need to remove screen spider... Answer This...
Analog JVC AV-2637S TV cannot...
Hi, I have a great but old JVC... Answer This...
Repair Service
Find Projection TV Repairman Near You:
