Question about Sanyo DP32746 32 in. LCD Television
My hdtv image goes out after a short time of being turn on but I can hear the audio or the voice, could you tell me what could be wrong with it, thank you.
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 11, 2010
  • Sanyo Master
  • 8,457 Answers
The tv have 1 or 2 a long board call a LCD inverter boards.These 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter board for the replacement.
Posted on Nov 07, 2010
No picture no sound loud humming sound for a short period when you turn it on than a orange light flashing at bottom where the blue light is when you turn it on.
AV cables reversed perhaps. Sounds like VIDEO (Yellow, Green, Blue or Red) cable is plugged into the AUDIO section. Perhaps you have switched the RED (Left audio) cable plugged into the RED (Component) Video cables. This would account for the loud buzz and since the set isn't getting an image it goes into standby mode. Just a thought.
Nov 25, 2010 | HP Pavilion MD5020N 50" DLP HDTV
My computer is dell insprion 1525 model. when i speak use in speaker that time voice is comeout changed. if female speak comeout that voice is male.
If you are using the Dell Webcam then i know what's wrong. Go to the Dell Webcam Consol click effects. If "Enable Audio Affects" box is checked then uncheck it. This takes away the audio affect you are hearing in speakers.
Hope this helps :)
Jul 10, 2010 | Dell Inspiron 1525 Notebook
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
I have Windows xp and gigaware usb stereo headset w/mic. The headset works, at least the mic and the speakers work. I can't get it to work with google voice. When I make a call through my laptop, the call...
First of all you installed Sound driver.
Than go to control panel and click on sounds and audio devices.
Than click on voice and reset it to default and restart your system.
I hop its working fine.
Regard,
Abhay Singh
Dec 09, 2009 | Microsoft Windows XP Home Edition
My microphone dosnt work but i hear voice tell me wt can i do
Microphone may be plugged into the wrong port - check the port.
Jun 11, 2009 | Computers & Internet
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Hearing double voice when monitoring through delta 1010
Check to see if you have your onboard sound turned on. If you do turn it off and this should stop the double voice.
Jan 07, 2009 | M-Audio Delta 1010 Sound Card
Voice delay and low picture pixels
The problem is lack of bandwith of the receiving signal from your daughter. The Skype server is located in the UK and all video and audio data signals go to and from the Skype UK server before it goes to you and your daughter. This lack of bandwith causes the video image to break up and a delays in audio just like a weak high definition signals to your digital television.
You can see your own video and hear your own audio from your WEB cam clearly, because the video and audio data does not have to go to the UK and back again, also your satillite connection is probably not as fast as a cable broadband connection. Your daughter may also experiencing the same video and audio problems.
Video data contains a lot more information than the audio data. Therefore there are a couple of things you can do to improve the situation :-
Get your daughter to and possible you as well (if she is also experiencing break up of video and audio), to reduce the video image size from 640X480 to 320X240 resolution.
If the video is still a problem then turn off the video all together and only communicate by audio, this will reduce the amount of data being transmitted and should give you a clear/clean audio.
Dec 08, 2008 | Skype IM
Sanyo DP32746 32 in. LCD Television Logo
85 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
