Question about Epson EMP 5500 Multimedia Projector
When i turn the projector on the fan works and the orange light comes on but when i hit power it makes a weird noise the light turns on for a second and then off and there is no picture.
    Problem Solver:
  • 6 Answers
You need to check the air filter (unless it is a DLP unit) tio make sure it isn't clogged. Most projectors will shut down to avoid overheating and damaging the circuitry. At times this may also be an indicator that your lamp has reach its end-of-of life stage, and given the age and model of your projector, you may weigh the cost of purchasing a new one.
Posted on Dec 18, 2013
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
marsrover
  • 682 Answers
SOURCE: turns off
IF YOU GOT BLINKING RED LAMP FOR 0.5 SECOND -UNPLUG THE POWER CORD AND CHECK THE LAMP IF IT IS BROKEN AND REINSERT THE LAMP AGAIN IF IT IS OK.CONFIRM THAT DOOR COVER OF THE LAMP IS CLOSED FIRMLY.-IF IT IS BROKEN CHANGE IT WITH THE SAME ONE.
IF YOU GOT BLINKING RED FOR 1 SECOND CONTACT WITH SERVICE CENTER.
Posted on Mar 24, 2008
SOURCE: dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Posted on Nov 03, 2008
SOURCE: Temperature indicator turns on in my Epson EMP-500
it appears that one of the cooling fans in ur projector is jammed or not spinning at the required speed!
ope the projector & observe the fans as u switch on!!!if the fans seem fine, then it could be a defective thermistor!
Posted on Feb 08, 2009
projdoc
  • 2237 Answers
SOURCE: Projector powers down as soon as LAMP lights up
the ballast/power supply needs replacing.
Posted on Dec 23, 2009
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Viewsonic pjd5111 projector has temp and lamp light on. not turning on
Hello
Check whether its cooling fan works or not. If there is any fault to the cooling fan, these symptoms you describes here can occur.
Feb 07, 2012 | ViewSonic PJD5111 Projector
When i turn on my projector it makes a loud noise like it is arking on something. Its a very weird noise. No picture. Fans are still going. Then it stops and status light turns orange. This happen while...
I have had this problem, it was the lamp module that was faulty.
If you have an old lamp, try that first to prove that is the current lamp that is the problem. I wouldn't want you to purchase a new one to find it isn't the lamp after all.
Good luck
Aug 10, 2011 | Office Equipment & Supplies
The projector turned itself off after couple hours of use and the Temp. red light came on. Power Light turned red instead of orange as usual. After 3hrs I turned it back on, cleaned the dust off the fan...
There are three temp sensor inside the projector and now your projector need full service but if the air filter becomes clogged with dust, the internal temperature of the projector will rise, the TEMP indicator will illuminate and the projector's power will turn off (the TEMP indicator will flash after the power is turned off) The air filter should be cleaned every 100 hours of use.
If you clean the filter with a vacuum cleaner to clean off any accumulated dust. then your projector working normally
Jan 03, 2011 | Panasonic PT-LB50U Multimedia Projector
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
No projection
This sounds like the lamp has not fired. Try a new lamp. If that fails to resolve hte problem, the ballast is the next assembly to be replaced.
Dan
May 12, 2008 | NEC HT410 Multimedia Projector
Feb 10, 2008 | NEC VT460 Multimedia Projector
Epson EMP 5500 Multimedia Projector Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
