Question about Toshiba Satellite A45-S150 Notebook
Can a Toshiba A-45 S-150 run a 160GB PATA drive--without partitioning?
  • jblock41 Nov 07, 2010
    I NOW KNOW THAT IT MUST USE A PATA; IT CAN ONLY ACCESS UP TO 120GB NO MATTER WHAT--SO THE CORRECT ANSWER IS: PARTITION THE DRIVE...
  • Toshiba Master
  • 32,281 Answers
The hard drive has to have a single partition for the operating system to be installed on the hard disk.
It cannot operate without at least one partition on the hard drive.
Posted on Nov 07, 2010
  • Chris Hingee
    Chris Hingee Nov 08, 2010
    Yes, partition the hard drive as a single partition to get the maximum disk space as a single drive.
    If you want, say for example, two partitions on a single hard drive then the total disk space of both partitions will equal to the total disk space of the hard drive.
    NOTE - The maximum size PATA hard drive you can install on your computer is determined by the BIOS.
  • 70 Answers
Yes it will work without partition the sata drive. But its good when you partition the sata drive.
Dear sir i have seagate ST3160215AS 160gb sata hard disk. in bios it shows 160 gb but in actual it gives only 149gb. i have tried to dm it but no dm matches it. then i tried ontrack to it. it shows 160 gb....
the hard drive might be damaged bad sectors
the operating sytem will take/use a certain ammount of space onyour hard drive
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
hope this helps you
Oct 23, 2011 | Computers & Internet
I am trying to partition and format 2 identcal Toshiba Laptop SATA HDD's. Using Windows Disk Management and Easeus softwares, both softwares are listing each harddrive capacity at 55gb. The actual capacity...
You would want to delete all partitions from the disk. That will get the raw space back. From there, partition; then, format. If you need more help, please ask, but from the experience level able; it sounds like you are right on track.
Dec 03, 2010 | Toshiba Computers & Internet
I have a Toshiba Satellite A75-s2762 laptop. I am looking for a compatible hard drive to replace the original one that has failed. I would like the largest hard drive that will successfully work with my...
With that model you need a PATA hard drive. You can go as high as 320gb hd in that laptop. Now the higher the GB the more it costs and well that is up to you. I personally would stick with a 160gb 5400rpm drive for decent size and decent speed.
Sep 21, 2010 | Toshiba Satellite A75-S2762 Notebook
PURCHASED A NEW HARD DRIVE MDL: WD1600AAJB-00J3A0 NO INSTALLATION SUCH AS CONFIGURING, PARTITIONING AND FORMATTING AND NO REFERENCE TO BIOS.
The bIOS should automatically pick up the HDD, Formatting is done via your OS, Configuring only applies to PATA drives nnot SATA ones and partitiong is done with a third party sofware such as partition magic.
Jumper settings for PATA drives are printed on the HDD label.
Mar 22, 2010 | Western Digital Computers & Internet
Will pata hard drive work on dell inspiron 600m? WD Scorpio Blue 160gb PATA drive
Yes, the Dell inspiron 600m uses the EIDE/PATA interface so your new drive should work fine.
Oct 04, 2009 | Computers & Internet
Acronis Migrate easy cloned hdd doesn't load win xp
You can use AOMEI Partition Assistant to clone your 60 gb hard disk to your 160gb directly. you can also use it to migrate your os to another disk if you don't want to clone the entire disk. http://www.disk-partition.com/copy-disk-partition-wizard.html
Sep 06, 2009 | Acronis Migrate Easy 7.0 Full Version for...
Trying too dual boot xp pro on toshiba tecra m5. conflict image of original xp pro, in slim select bay hdd. Need help with settings so as the same op system can be used on both drives.Any help would be...
in order to dual boot something.... you need to partition the hard disk... if there's only 1... you need a program that will create another partition from drive C...
for example the size of your Hard disk(drive C) is 160gb
you need a program that will split 160gb into 2 it should come out and you will have now two drives (C & D) with a size of 80gb each...(It depends on how large you want the other drives to have)...
the program is called Partition Magic 8.0 if you want that program.. i can send it to you... just contact me in my yahoo messenger... derick_10_02@yahoo.com
now it's time to install the Windows XP in each drive then you'll have a dual boot... or you can install Windows Vista on the other drive... so therefore you'll have Windows Xp and Windows Vista in one PC...
hope it will help you... tnx
Jun 07, 2009 | Computers & Internet
Hard drive compatibility
This motherboard is compatible with PATA/IDE Hd's running at 133/66/33Mbs. & ATA/SATA 1.5Mbs drives. The SATA's run faster. This board will not handle a SATA II's speed but it will still run on the P5P800-VM board. The links below show good buy's on both PATA/IDE & SATA I & II. Seagates for their 5yr. warranty.
Seagate ST3160215AS 160GB ATA/SATA
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117012
Seagate ST3160215A 160GB Ultra ATA/100
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117010
As far a size, that is up too you. Windows can handle 5 time these sizes.
Please don't forget to vote.....
Dec 22, 2007 | ASUS P5P800-VM Motherboard
Toshiba Satellite A45-S150 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
