Question about Samsung SyncMaster 712N 17" Flat Panel LCD Monitor
I have a syncmaster 712N samsung monitor and i recently changed my operating system to windows xp erasing all existing data (specifically drivers). Now when i turn the computer on the screen doesnt look right and when i go to Display(in control panel)>Settings>Screen resolution, i cant increase it neither can i increase color settings, what do i do?
Most likely you will need to reinstall the video card driver. This will allow you to select a more desirable screen resolution.
Posted on Nov 07, 2010
  • mjhart1221 Nov 07, 2010
    do u know which 1 exactly?
  • Jake Nov 07, 2010
    It will depend on what computer you have and what video card is in your computer. You can try typing "video card driver (your computer make and model here)" in a search engine.
    Also, the manufacturer of the computer should have the needed software on their website.
    Sniper:
  • 63 Answers
Not optimum mode recommended mode 1280x1024 60hz syncmaster 712 n pop up occasionly I have to shut down computer
Your video card and computer memory may not be sufficient to run in the recommended "optimum performance mode" that Samsung and Windows both suggest. Please try setting your display setting at a lower resolution such as 1080 x 760 which is still quite excellent. Otherwise you may need to buy a better video card or increase system memory to run the higher mode graphics.
Good Luck!
Jan 11, 2011 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Where can I download Samsung CyncMaster 757 dfx monitor driver?
Which operating system are you using if win xp or win 7 it dosent need any driver
any way the driver for windows 98 is not possible.
Dec 05, 2010 | Samsung SyncMaster 757 DFX (White) 17" CRT...
SyncMaster 712n doesn't come on
1st you check Local tech after that buy the monitor.
Mar 11, 2010 | Samsung SyncMaster 712N 17" Flat Panel LCD...
I need driver
No, you don't need a driver. This is a "plug-and-play" device.
Your Operating System (Windows XP??) will adapt to the capabilities of the device.
Jan 07, 2010 | Samsung SyncMaster 1100MB 21" CRT Monitor
19" Samsung SyncMaster washed out display
You either have a backlighting problem or the power supply is getting weak and starting to fail.
If you have another computer...connect it and see if the results are the same...also check your cables, analog and/or digital for any faults.
Good luck...i hope this helps.
Jul 18, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Letter size
In your display properties, if using Windows, you can change the font dpi. It's usually set at a default of 96dpi & iy allows you to either change to 120dpi or a custom size if you need bigger than 120. Hope this helps.
Jul 02, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Samsung
Please try to connect your monitor to another PC, if still the problem exist, then probably an internal electronic part/s is cold soldered / defective, which I suggest to bring the unit to an authorized service center to fix the problem. regards
Jun 02, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Monitor issue
does it work fine on another computer?
Mar 18, 2017 | Samsung SyncMaster 971P LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Samsung SyncMaster 712N 17" Flat Panel LCD Monitor Logo
305 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
