Question about Asko D1876 Dishwasher
I have an Asko DW1875 dishwasher (10yrs old) which has just recently started having problems. The initial symptom was that during a washing cycle, unit showed '1' and inside became very hot (melting some plastic cups/plates in unit). On further investigation (with diagnostic mode), the dishwasher is filling and draining with no problem. When circulation pump runs there is barely any water pressure in blades (just dribbles out) and water leaks into undertray via a plastic white tab near front (visible when observing via open toe panel at rear). I presume that when water level dropped below heating element, this caused the overheating inside machine. Eventually, water in tray triggers an F2 error. Is this a simple clogged pipe or an expensive broken part? Trying to decide between service call or machine replacement.
4 Suggested Answers
  • 641 Answers
SOURCE: F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Posted on Jul 27, 2007
SOURCE: F2 Error Message on my Asko D1776
Clean out the pump...they tend to get clogged with grease...then poor washing up liquid in the strainer and poor a couple of kettles of boiling water in the strainer.
It worked for me on my Whirlpool dishwasher.
Posted on Feb 10, 2008
SOURCE: Trying to sourse a main
if the product is under the electrolux group try www.partnship.com.au-
Posted on Apr 06, 2008
Is my asko d1776 repairable. It's currently not going into wash mode. The Blade are not turning and washing.
The motor is not getting switched on at the proper time. The timer / cycle selector is the problem and is easily repairable.
May 25, 2015 | Asko D1776 Stainless Steel Built-in...
The soap isn't emptying out of the compartment during the wash cycle. 1. We didn't load any items too close to the dispenser. 2. We didn't use the Rinse program, just main wash cycle. 3....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 01, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
Dishwasher begins to fill then stops with no further progress.
Welcome to FixYa.
Based on hoe you`ve described the issue with your Asko, initially it sounds like a faulty inlet/water fill valve...
But, I`d like to clarify the symptom first. Does the unit complete the fill cycle and then do nothing, or it just energizes the fill momentarily then does nothing ?
Also I will ask to verify the model is an Asko 1375 ?
I`l watch for your reply.
Regards,
Macmarkus :)
Sep 02, 2010 | Asko 1375 Dishwasher
Water in the bottom at the end of the cycle
check the drain spigot under the sink to see if there is a blockage.also you can fit a check kit to the drain hose.you can get it from asko
May 31, 2010 | Asko D1706 Built-in Dishwasher
There is an Asko D3112 on our office. I've been
it is programmed to continue where it left off. It is best to remove chunks of food from plates rather than rely upon the rinse system.
Oct 10, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Asko 1503 error code
Hi, Sounds like a bad door switch. Here is a site that may help you. error codes... ttps://removeandreplace.com/2015/12/22/asko-dishwasher-error-codes-how-to-clear-what-to-check/ch.
Feb 10, 2018 | Dishwashers
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Open Questions:
See all Asko D1876 Dishwasher Questions
Asko D1876 Dishwasher Logo
83 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
