Question about Marantz SR-7400 Receiver
My Marantx SR7400 receiver turns on then back off when I hit the power button. I see the 'standby' light lit. When I hit the power button, the 'standby' light goes off like it should, I hear a click like the unit is turning itself on but the LED display does not light and the unit turns itself back off in a matter of a second or two. Then the 'standby' light comes back on. It worked fine, but one day when I turned it on. this happened without notice.
    Top Expert:
  • Marantz Master
  • 49,836 Answers
The power supply may have failed without any symptoms.
Posted on Jun 19, 2017
5 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: the receiver is turning itself off - i.e back to standby.
If you don't use the remote control is it okay? If so, tear apart your remote control, use a Q-tip to clean all the lines in the circuit board where the rubber contacts touch. Then make sure that the rubber buttons don't have any 'gunk' on them that are making them stick. Clean the rubber pad with a qtip with dishsoap. Dry well, put back together and see if she works. Report back on your success. Good luck.
Posted on Dec 29, 2009
  • 417 Answers
SOURCE: hello i have a marantz receiver sr7400 fuse
Unplug the unit. Carefully unscrew the screws for the case. Probably 4 screws, 2 on each side of the unit. Remove the cover. Look for the fuses, and replace with exact same type/specs of the faulty fuse. If the fuse, is on a printed circuit board, be careful dislodging the fuse. Hope this helps.
Posted on Apr 07, 2010
sonicboomele
  • 1557 Answers
SOURCE: For no reason I know of, my Marantz SR8001 will
blinking power lights are a factory setting to inform the customer there is an internal electronic fault. and the unit needs to be repaired by a service pro in 99% of cases the owner can do nothing to fix it.
send it in
best luck
Posted on Oct 14, 2010
manu147
SOURCE: marantz sr5600 reciever click and goes to blinking standby
I have the same problem. Earlier it got sorted out itself and now it has started coming up again.
Posted on Sep 01, 2012
Sometimes when I point the remote at the TV to turn it on, the infrared "receiver" is not lit up. I have to press a button on the back of the TV to turn it on.
That isn't the 'infra red receiver', that is the standby button. When it doesn't come on, it usually means the power has been cut and the set has turn off, as opposed to being on standby.
Jan 23, 2016 | Televison & Video
Sylvania plasma tv will not turn on
power supply board has defective components,check for swollen capacitors and replace them,if problems still not solve email me at rspoliah@gmail.com .for further instructions
Aug 14, 2014 | Sylvania 6842THG 42 in. Plasma HDTV
Fisher receiver rs 737
No answer, but...
I have a similar problem... I can power up my rs-911, then about 3-5 sec. later, it shutsdown (standby light still on)... What in the tarnation is going on? All 3 fuses are OK.?.
Nov 18, 2013 | Fisher Audio Players & Recorders
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Power/standby light is lit. When I try to power on, the display shows "digital" then "av surrond", then the unit powers off; the power/standby light flashes. I tried unplugging to reset, but no luck.
you receiver is reporting that the impedance of the speakers is incorrect the manual says that it needs impedance of 6 to 16 ohms and when simultaneously using a and b it needs 12 to 16 ohms. but you receiver is also saying that the problem is with the av surround digital channel so the impedance of the speakers is either too low or too high check the impedance of the speakers and if they are correct try them on another circuit and see if the problem follows the speakers.
Also, it may be that the positive wire is contacting the back of the receiver and grounding out. If so reduce the length of the bare wire and reconnect.
you may have to reset your receiver to clear this state.
turn off receiver or start from the off condition,
hold down surround mode left and right and turn on the receiver hold all 3 buttons till the display starts flashing at intervals of aproximately 1 second then release the buttons, if this fails to work try the procedure again.
Cheers!
Feb 14, 2010 | Denon AVR-1601 Receiver
I have an Onkyo TX-8511 Receiver. The unit has power because the standby light is on, but nothing happens when I press the power button or try and turn it own with the remote. I have Onkyo HTS907 that...
You have two devices that won't power on. Doesn't that suggest a source power problem? Did they ever or never work where you are now or anywhere else? Or did you just come back from overseas and forget to set them up for U.S. power?
And you're not daisy-chaining the two units together, are you? That's a no-no. There's a wattage limit to what can be connected to the convenience outlets. Power amps are not usually supported.
Try isolating the two units and shoot each bug separately. Plug them in somewhere else. Disconnect speakers and try again.
C'mon back with the results.
May 08, 2009 | Audio Players & Recorders
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
Marantz SR7400 AV Surround Receiver
Try resoldering the main bridge rectifier on the power amp circuit board. You will have to remove the board from the heat-sink. The rectifier is mounted off the side of the board and screwed to the back of the heat-sink. Resoldering this usually cures that problem.
Oct 07, 2008 | Televison & Video
Marantz SR-7400 Receiver Logo
192 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
