Question about Dynex 32 in. LCD Flat-Panel HDTV
We just bought our Dynex 32" LCD HDTV and we finally got it plugged it in. The picture is terrible. it looks fuzzy. We changed the settings with the contrast to see if that would help, but it still looks terrible! please help!
  • Dynex Master
  • 8,457 Answers
Return the thing,get a new tv replacement.The tv itself have a problems.The tv Tuner signal board that the board on the tv itself that taking in the incomming broadcasting tv signal cable have problems.
Posted on Nov 07, 2010
I just bought 32 inch 2 hours ago, and am using it with an antenna. Almost every time I turn to channel 5, the remote freezes and I can't even use the buttons on the side of the tv. I have to...
This is my second set in as much days from Best buy. Exact same problem.
Sep 21, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Remote doesn"t work. Only have
check that all of your cables are plugged in correctly and that the input is set to to correct cables on the remote there is a button that should say input press that a menu will appear and then you can scroll through your input options keep trying until one works
there is also usually a button on the tv that does the same thing
Mar 06, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Just bought an open box 32L152A-11. plugged in the electrical cord and inserted the input cable and screwed it in securely. fios box is not an "hd" so i am not i nserting a hdmi cable. i...
from what i gather you are trying to get hdtv to work with rca cables without using an hdmi cable . if this is correct then all you need is RGB cables . just like rca but they red green and blue . look on the back side of your tv , there should be a set of RGB inputs and also rca .
Feb 09, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I have my laptop plugged into my 32" Dynex TV and the only thing that is showing up on the TV is my desktop picture and the resolution preferences window when i open it. Is there a way that i can fix this?
sounds like your set up on extended screen where your laptop still show desktop and your tv shows only the desktop picture. if you have a fn button or like, should be next to the left ctrl button press it and on my laptop its f4 but maybe different on yours should scroll through the different output modes. failing that check your output modes on your laptop going to control panel/display properties and change your settings. hope this helps i can't tell you how to change them or what to change them to as i got a intel setup program for doing it.
Oct 23, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Trying to change tv format on my dynex 32 LCD
You are looking for a picture size, format or screen size button on the remote control to solve the issue. If it connected to a HD cable or satellite box then they also have format or picture size settings.
Apr 13, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Horrible fuzzy display on my external lcd tv monitor - sadness
You need to change the resolution and colour quality under graphics properties on second monito. Put the settings back under the advanced tab, your just pushing new monitor over its limits. You dont need to have the same resolution set as your PC screen. Hope this works for you.
Mar 18, 2010 | ASUS Eee PC 1000HE Netbook
I connected dvd player to dynex 32 inch tv. what
You should be connected to the AV input 1 slot. Change the input on the TV to Input 1
Jan 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I just bought a 42 INCH LCD WIDESCREEN HDTV Dynex brand and I need help getting the optimal video display settings
Whatever is pleasing to your eyes. we are all different, remember beauty is in the eye of the beholder. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Fuzzy pic on Dynex 32 LCD TV
I am sumising that you have checked the menu controls on your tv and are recieving your signal from the cable box , so therefore if it is not comong from the Aerial and direct from the cable company then the picture should be clear .. However sometimes people dont check to see if the signal is RGB or composite from the box RGB is usually best if you have a scart socket connection or SVHS if your set has that capability .. sometimes people have an old VHs recorder and the sinal is coming from that to the set through the Aerail fly lead if it is you will probably find they are conflicting giving you a poor picture retune your Video to another channel instructions should be in its manuel if not come back to me ... reagrds Vortash
Mar 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
216 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
