Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
My seagate external hdd 500gb is not working and is not detected and regonised in any pc..
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Posted on Nov 07, 2010
Hi, I have a seagate freeagent external disk with 500 Gb capacity, I had long time without to use my diks, then when I tried to use, It doesn't work, the power source is Ok, but my disk it It doesn't...
is the hdd getting detected....??? if it got detected then format it and try to use... if it is not detected then, let me know, i shall assist you further...
May 17, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Suddenly stopped working
i think your hdd is dead,Because your hdd light not even turn's on....
Apr 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagat 500GB Portable GO external HDD not recognised on PC
first of all you should try it on deferent pc , if its ok then that leads us to insufficient power provided through usb ports , try using back usb ports not the ON-front, and if the problem still try using dual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.html and if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changed if you cant find a similar one you may buy a new empty cage
Mar 05, 2010 | Computers & Internet
Buffalo hdd not detecting
Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
Check there to see if the drive is listed, "online" and has a "Healthy" Partition.
Dec 17, 2009 | Buffalo Technology 500GB DRIVESTATION...
Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Nov 06, 2009 | Seagate Computers & Internet
USB Not detecting
First check if other usb data drive like is pen drive is getting detected. Check all the usb ports. Check the Seagate drive with other computer if you have.Restart the system in safe mode and check.Try to create new admin account and check .If also chck the usb cable to make user it is not defective. If nothing works probably your hdd is gone bad. Good luck.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Brand new Seagate barracuda 500GB SATA hdd not detected
http://www.seagate.com/staticfiles/support/downloads/firmware/ http://atulchitnis.net/files/seagate.pdf
Jun 20, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
I havea seagate 500gb external hard disk, when i connect it wth the laptop the hard disk is not recognised on my laptop. i have windows xp professional installled in my laptop
Click on the link below and then click on the "Fixit" button. Windows has a patch for all external devices not recognized by PC's including HD's. This is especially an issue for those who've recently installed SP3. Best of luck with your problem.
Greg
http://support.microsoft.com/kb/925196
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have seagate 500gb hard disk which is not recognised by win xp what should i do
If using USB try it on another USB port, if on eSATA then try using USB to see if it will detect it via usb
Have you got another computer you can try it one just to ensure that the hdd is actually working ?
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
476 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
