Question about ASUS Eee 4G Notebook
I would like to lock my touch key pad (I prefer to use mouse). Currently, I keep hitting the pad with my palms as I type and sending the cursor all over the place. Can you help? Thanks Denise
    Problem Solver:
  • 15 Answers
There usually is a certain way to temporarily disable the mouse
look for something like that on the "F" keys (F1 F2 F3) (like a cross over a picture of a mouse pad)
you might have to press the "FN" key and "F" (depending which one had the picture) at the same time .
if not check for options (try right clicking mouse pad icon in system tray maybe) or look for an option the control panel
tell me if you got it figured out
Posted on Nov 07, 2010
  • dtart Nov 07, 2010
    Thanks
    I have since solved the problem - looked up the ASUS site.
    I simply had to press Fn F9 which disables the touchpad, so that I now only use the mouse - which is what I wanted.
    Thanks again
  • Dave t Nov 07, 2010
    sure ;)
While typing cursor jumps of to different lines and different areas
If you are using the touch pad, try turn it off and using an USB mouse. I have found that my palm hits the touch pad and causes random cursor movements.
May 12, 2011 | HP Pavilion dv4000 Notebook
How do I disable the mouse pad on my ASUS K52F Lap top? I prefer the remote mouse but I keep touching the mouse pad when I type and the cursor just goes someplace else.
Hey man had the same prob but found how to fix it :). go to control panel click hardware and sound. then you will see devices and printers, under that will be, add device, add a printer, mouse. Click mouse! Then click the tap ELAN, there is a box to check, it says, "Disable when external USB mouse plug in". there you go. Hope that help.
Feb 17, 2011 | ASUS Computers & Internet
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Oct 24, 2010 | HP Pavilion dv4000 Notebook
My cursor jumps around while I am typing often starting up in the middle of typed area oping r if I pause while ty it just happened here....now.. see "oping" r "ty"????!!!!!!
This is usually due to your base of your thumbs touching the mouse pad while you are typing. Some touchpads will let you disabe the mouse pad while typing. Go to control panel-mouse- and look in the properties. There may also be an option to disable the touchpad when you plug a mouse in. Hope this helps
Aug 24, 2010 | Computers & Internet
As I type the cursor will jump backward whverever it wishes as follows. As I type the cursor will jump backwarderever it wishes as follows wh
This happens for 1 of 2 reasons: 1. Either your wrist hits the mouse pad and that makes the cursor move
2. If your mouse moves all the time without your control you need to have your palm rest replaced
When this works vote me a 10
Aug 22, 2010 | Dell Inspiron 1525 Notebook
When typing an email the keys skip back to the
When I have seen this happen, the touch pad was set overly sensitive. When you are typing, your palm may be moving the cursor. If this happens at other times, then this can be corrected in the control panel. Go there and click on touch pad. It will have settings to set the sensitivity for the mouse pad, speed, double click/single, etc. You can change the settings to be more suited to your hands.
FYI: Older laptops were more susceptible to touchpad errors and I have even seen the area on either side of the touchpad to cause the mouse cursor to move and jump.
Good Luck
Dec 16, 2009 | Toshiba Computers & Internet
My Sony laptop cursor jumps around when typing
Yes, you are accidently hitting the touch pad.
Trust me--that is what is happening. Some laptops have VERY sensitive touch pads. If you can disable the touchpad and use a mouse, do it. (that is what I do, as I suffered the very same problem.)
On one customer, I had to actually open the computer and disconnect the pad.
If you can't disable it (many new computers have some sort of switch to disable it, even if it's a combo of the Fn key and one of the special function keys, practice better hand position--raise your seat or lower the laptop to keep your wrists from drooping and getting your thumb near the pad.
Aug 24, 2009 | Sony Computers & Internet
When typing the curser jumps to a different position
This is because you are touching the touch pad with your palms. when typing avoid contact with the mouse pad in your laptop. I hope this will help. Thanks.. Please rate this!!
Aug 16, 2009 | Acer Computers & Internet
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Cursor skips lines while typing
My experience: cursor suddenly moving backward when i was typing, or moving somewhere else on the page. I would be typing and text suddenly would get highlighted. I followed someone's advice to disable the touch pad. Since I do have a mouse & key pad that was all i had to do.
HOW TO DISABLE THE TOUCHPAD FOR ACER 3680 AND OTHERS??? PRESS Fn +F7
Yep, it was that simple. At first I made sure i typed without my fingers or palms touching or near the touchpad. I noticed it seemed to stop or happen less. Soon as I disabled the touch pad all is back to normal. Yet I spent hrs trying to find out how and there were all these posts by people suggesting downloads and other more complicated things etc..
May 12, 2007 | Acer NSK8458AN Keyboard
ASUS Eee 4G Notebook Logo
207 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
