Question about Whirlpool AKZ159IX Oven
I'm looking for a manual for a whirlpool oven AKZ 431
    Sergeant:
    Champion:
  • 382 Answers
Try contacting the manufacturer and se if they can supply one also check online to the manufacturer and try to download a printable one
Posted on Nov 07, 2010
Testimonial: "I've been trying to find one to print - that's where I'm having trouble."
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
Aug 06, 2014 | Whirlpool Ovens
Need instrucion manual for whirlpool akz 155
Please check on the link below:
Register your product:
http://www.whirlpool.com/contact-us/
Nov 11, 2011 | Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Whirpool akz 431/01 chyba F 02
Hello & Welcome to FixYa
F2 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 10, 2011 | Ovens
Akz 451 timer, clock, light and fan all working - oven not warming up - power RCD tripped before fault noticed
I would recommend that you replace the oven element, located at the rear of the oven compartment behind a removeable cover.
Oct 12, 2010 | Whirlpool AKZ159IX Oven
Whirlpool AKZ 446 Electric fan starts but oven does not heat up ?? Is the element easy to replace/fit? Thanks
Yes , the element is easy to replace
Remove the cover at the rear of the oven, there you will see the element, undo the screws securing it, and replace the element.
This should solve your prob.
Good luck..
Dec 29, 2009 | Whirlpool AKZ159IX Oven
AKZ 451 will not heat up
element,make sure clock is set though
Jun 29, 2009 | Whirlpool RBS275PD Electric Single Oven
Door hinge of oven detached on one side
two hidden levers on end of hinges. When raised, door able to be re-inserted or completely detached.
very simple once i discovered levers on the hinges.
Dec 19, 2008 | Ovens
Whirlpool AKZ159IX Oven Logo
905 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
