Question about T-Mobile Sidekick II
My sidekick 2 works perfectly okay. the only problem is that its display doesn't glow. u can see stuff on the screen when u show it under a light source though. but the screen's lighting is gone. i hope u've understood the problem.
Please help me unlock my sidekick2..it requiring a special code to work here in Africa with my new sim Card....Please Can you help?...Here is my email address jansilver102@yahoo.com.
Posted on Nov 08, 2010
I turned the phone on and there is nothing on the display. I can hear sounds but nothing shows up on the display. No menu...nothing...just a blank screen. This is on a Sidekick 3.
IF you sidekick 3 screen is blank then the lcd needs to be replaced. Replacing the Sidekick 3 LCD screen is pretty easy and cost about 25 dollars if you buy it from ebay.
Here is a guide for it Sidekick 3 LCD Flip Screen Replacement
and here is a link to the screens
Buy a replacement Sidekick 3 LCD screen.
Nov 06, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick Gekko Wont Turn On
try to charge phone battery in 12 volts dc
Jul 17, 2009 | T-Mobile Sidekick ID Cellular Phone
No display light
It is possible that the backlight on your LCD is burned out. If you have a friend with a Sidekick LX, see if you can swap the lcd screens quickly. This will let you determine if it is the phone or the LCD screen
Here is a link to show you how to remove and or replace the Sidekick LX Screen
Sidekick LX LCD Screen Replacement
Apr 07, 2009 | Sharp Sidekick LX Smartphone
Display went from extremely dark to complely black
Hello there.
I understand that your Notebook is not showing the display lights. To isolate the issue please do the following troubleshooting steps.
1) Check the display with external monitor. If the external monitor is showing the display then the problem is with the LCD screen. If the external monitor is not showing the display then the problem is with the display card.
2) If you have any torch light or a cell phone , try focusing the light on the LCD screen after the Notebook is powered on and check whether you are able to see the texts and images on the LCD. If you are able to see the images and texts then it is the problem of the LCD back-lights. The lights which glow at the back of the LCD panel are not working.
If your Notebook is under warranty HP will repair it free of cost.
Contact HP customer chat center for more information regarding the details of the repair and the procedure for sending the Notebook to HP in case of repair.
For contacting HP chat support click on this link or copy and paste it in address bar of a web browser.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Feb 17, 2009 | HP Compaq Presario M2010US Notebook
MY SCREEN ISNT LIGHTING UP
ebaby-
If the screen is glowing white, then you can try reseating the flex cable at the lcd.
Here is a guide on how to do that.
fix white screen on sidekick ID
Try that, if it doesn't work then a new lcd assy will fix
Dec 13, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 problems
Antonio-
You may be able to fix many of those things yourself. The trackball proabaly just needs to be clean. Does the LCD have a white screen when it is on? The Camera, well that may take some work.
For the white screen check out here: http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
If it is not white, a new lcd can be had for 45 dollars on ebay.
they are easy to replace.
replacement of the Sidekick 3 LCD flip screen.
To clean your track ball, follow these instructions:
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
Apr 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone will not turn on
Sounds like your charger port is busted. Ti is a common problem on sidekick 3 and can effect sidekick IDs as well. A fairly cheap workaround is to get an external battery charger. It will have a slot to charge the sidekick battery external formthe phone. They sell on ebay fior about 25 dollars.
The sidekick ID and sidkeick 3 batteries are the same so it will work. Check then out here
Sidekick ID battery charger
Feb 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Backlight on sidekick 3
Because your screen is broken and that can only be fixed if you have it replaced.
Jan 14, 2008 | T-Mobile Sidekick II
Sidekick 3 screen problem
This procedure usally will fix a white screen on a sidekick 3 or a sidekick ID.
Try this before you replace the LCD
Dec 06, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Problem when I open the phone, please help!
Okay I work for Sprint as a advanced technical support. Your screen is busted I can tell that when you said it was orange. The LCD is non existent and the colors have mixed. I hope for your sake that you have insurance because it is time to get a new phone. and yes when it is closed the sub screen works fine because it is two separate screens and your main screen is the one busted. It is hard to say if you will be able to get your contacts back because in most cases I have seen that information is lost. So it is time to take it to a Sprint Nextel and Repair center. Hope that helps :)
Oct 13, 2007 | Sanyo SCP-7300 / RL-7300 Cellular Phone
T-Mobile Sidekick II Logo
29 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
