Question about Brother HL 5170DN Laser Printer
Paper has jammed rinter - Brother HL 5170DN Laser Printer
    Problem Solver:
  • 9 Answers
Paper jam is of two types.1.while spolling half paper will come out tom tray.remain jammed in rollers.This can solve by switching the printer power off and remove toner catridge from printer.Then power on the printer.lift the top rollers cover and reset as it is.The paper will come out without any difficult.2.Paper jam inside the toner catridge by rolling itself to drum.Switch off the printer power.Remove toner catridge from priter.Unscrew the toner catridge cover screws.remove drum from toner catridge .Utmost care should be taken while removing jammed paper from drum.Reassemble as it is and set.
mohanraojagan@yahoo.com
Posted on Nov 07, 2010
I have a lexmark x6530 printer and i have a paper jam how do i get the paper out it tore when i tried to remove it
Please try this approach:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Mar 11, 2012 | Lexmark X3650 Printer
How do i f ix error8on hp m1132mfpp rinter
i would clean it out make sure there are is no paper jams or dust in
Feb 29, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Paper jam warning
There must be somewhere still a tiny piece of paper. To check if the tomer is also good without a piece of paper stuck, put in a new tomer and see if the light is fine then. also try not to overload the paper tray just a few papers there and make sure there is no paper open all doors to the printer top and side and look for that small piece that is stuck somewhere
good luck
Please rank me good
Jul 13, 2010 | HP Office Equipment & Supplies
I have a Dell s200n printer, the green light bleeps and states load/ remove paper, I have tried loading new paper removing etc however nothing works, I have reset the machine and still the error stays, can...
you have a paper jam or a bad paper sensor. open the back/rear and look for ajam in the fuser. if no jam you have to call a rinter tech to find the bad sensor
Dec 30, 2009 | Dell S2500N Printer
My rinter keeps saying e2 what does mean
Error E2 means paper Jam and is it a Canon printer ??
Make sure you open printer slot and take out the jammed paper, it there is one.
Retry and hope it works !!
Thanks !
Sep 08, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Dellv305 printer scanner copy
hi : mommagreen19 ,
one common problem faced (not by all )...with this printer model is  not able to feed the paper thro .
if u have sure the paper has been fed properly as instructed in the manual ., then , open the front cover of the p[rinter ., u should see the cartridges .,
r the cartridges located in the centre ?
if yes : then the machine is ffine .,
if no : its carrier jam .,
for  carrier jam : simply oull the carts to the centre and restart the printer .
again ., if u think that the printer keeps giving to probs ., call dell @ 18006249896 and check if it still in warranty ., and if so get a replacement .
hav a gooday !
Jul 27, 2009 | Dell V305w All-In-One R840635AU InkJet...
Printer don't work...
ok
power off the rinter.
then remove ink cartrdge thencheck there is not any paper jam.then refix again ink cartridge.let me know please.
Feb 03, 2009 | Office Equipment & Supplies
4"x6" Photo paper is stuck inside the [rinter and won't unjam. I can't even see it from the back or front of printer
There is always a way to get at the paper but it may mean taking apart some of the printer to access it. Best solution is to make sure paper is removed more carefully and it doesn't rip when you remove it.
Nov 18, 2008 | Office Equipment & Supplies
Poor Printer Quality
If you have the old drum put it back in and see what happens to the copy. if is better, then yu may have a bad new drum. They do have them. Poor copy quality is normally drum or toner in these Brothers. This model is an excellent machine by the way.
Jul 22, 2008 | Brother DCP-8040 Copier
Paper Miss match
Please select printers and see the properties and there will be a d efault paper size which may be lette A3 etc selecrt it to your desired paper size in the settings Ok.
Mar 05, 2008 | Samsung CLX 3160fn All-In-One Printer
Brother HL 5170DN Laser Printer Logo
205 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
