Question about Canon EOS 20Da Digital Camera
Sloooooowww speed I LOVED my 20D the first two years I had it. Then last spring it started slowing down - I was no longer able to fire off shots like before in multi-shot mode. Then one day it wouldn't stop clicking off shots. I turned it off, took the battery out and let it sit for a bit. Then it stopped working altogether and I got an error 99. It went into the shop and Ritz Camera said they fixed it - but they didn't. It worked one hour and did the same thing. I loaded a firmware update on it and now I can shoot again! No more error 99 - but it is slow - very sluggish and forget multi-shots for sports. I was shooting soccer tournaments, but now...I can barely get it to fire. I might as well have a point and click. What's wrong? Have I just worn it out? Help!!
  • rsbpublish Jun 15, 2008
    Thanks for the solution, but what does that entail and is it something I can do myself?
    Sergeant:
    Champion:
  • 248 Answers
Try cleaning your camera.
Posted on Jun 15, 2008
The Drill has little to moderate use over the last 25 years just developed a problem:
Check the carbon brushes on the back of the motor. It sounds like they are worn or the spring that holds them against the commutator is broken.
Sep 17, 2015 | Speed Drills
MB 1992 W124, engine turns will not always start or if starts will stop.
If you have an external fuel filter, good idea to replace and then take for test drive. If problem still present, might want to cheek fuel pressure.
There are a few other components that could cause your issue. A fuel pump that may be going bad or there is lots of dirt inside fuel tank. Another problem could be a bad fuel pressure regulator.
Do you have any codes in your engine control module ?
Jun 22, 2017 | 2002 Mercedes-Benz C-Class
DRYER HAS HEAT BUT WON'T DRY CLOTHES REMOVED VENT ON BACK OF DRYER AND DRYER SOUNDS LIKE IT SPEEDS UP AND SLOWS DOWN
you have to clean out the dryer,do this once a year if it's gas.unplug the dryer,remove the vent line,if it's a long run blow it out with a leaf blower,first make sure there's nothing like a screen or something on the outside duct then blow all the lint outside,next you have to clean out the duct that the lint filter slides into,then vac out the lint in the cabinet where the motor is then with a shop vac blow off the motor and blow out the cabinet and all the gas parts,do this once a year and your clothes will dry on time,your dryer parts will last longer and most of all you won't have to worry about having a lint fire
Jan 14, 2011 | Whirlpool LGR5636L Gas Dryer
I have a canon powershot a520 and it refreshes vary slow so it takes forever to take another photo. How do I fix this?
I've got a A520 also, and I think theres a few reasons why it can take a while between shots.
1) When using the flash, flash needs several seconds to recharge, this is unavoidable.
2) Some SD cards are slower than others. Make sure you buy a fast one. Note too that a 2Gb or 4Gb card will slow down your camera between shots, compared to a smaller memory card, such as 1Gb, or 512mb.
3) If using a slow shutter speed, such as 10 or 15 seconds, I've found it takes longer to take the next photo. This is unavoidable.
4) You could lower the resolution of the photos you're taking, this will enable you to take photos faster, and may still be good enough for applications such as Facebook, ect.
5) Another trick is to use the multiple shots option. For some reason you can take more photos more quickly than if you manually take each photo. Flash, and slow shutter speeds may still slow down the camera, if used.
Hope these hints help!
Nov 22, 2010 | Canon PowerShot A520 Digital Camera
Benjamin Air Rifle Model 342 not building pump pressure
Springs tend to loose their performance after a few years is air rifles. Check also the seal/o rings on the piston rod and the blow hole. I found waxing it with Vaseline makes it last longer and seals more.
Mar 27, 2009 | Dmm Benjamin Air Rifle
My maytag dryer does not get hot how can i fix it the model number is dg212 series 01
We bought this machine last year, converted it to propane & have loved it. All of a sudden there is no ignition ( fire). I have taken off the front & cleaned everthing I could see. Still no fire. I have check the gas supply, the drum is spinning, the only thing I think I heard last year right after it started and right before the "FIRE" was a clicking sound? What ever you might sugest would be greatly appriecated! Thank You, Don Wagner Jr @ SmoothSeal1@aol.com
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
"busy" Error
check your firmware version and update if necessary. Usually you get the "busy" message when your camera is writing to the card and it's possible the card isn't quite right - a format should fix it. Alternatately you might try a different CF card to see if the problem goes away. Good luck!
Sep 14, 2005 | Canon EOS-20D Digital Camera
Dead Batteries
AA's only last for 30-40 shots and should only be used as a very last option.
Sep 14, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
Canon EOS 20Da Digital Camera Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
