Question about Emerson MW8991SB Microwave Oven
Microwave is not heating food it turns two red lights on when trying to heat food
  • Emerson Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 22, 2011
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Posted on Nov 09, 2008
bestdarngood
  • 3037 Answers
SOURCE: it turns on ...lights up but doesnot heat or warm the food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
ginko
  • 19396 Answers
SOURCE: LG Microwave does not heat food
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on Apr 27, 2009
  • 1214 Answers
SOURCE: Samsung microwave doesn't heat food.
Microwave ovens that do not heat, and failed as you have described, have 1 or more of the following failed components, in order of cost -
1) Fuse
2) Diode
3) Capacitor
4) Transformer
5) Magnetron
4 and 5 are interchangeable when it comes to cost.
Try replacing 1 and 2, then 3, then it's decision time of whether to buy parts or replace the microwave.
Posted on Dec 11, 2009
Microwave lights up, turntable turns and fans run however food does not heat up. I have checked to ensure the power level is up which it is. Tried the express 1 minute as well as using the time mode and...
The problem is one of three things, the magnetron "common issue" the high voltage capacitor and diode can be a factor, all three work together in conjunction with the high voltage transformer to generate the high voltage that heats the food.
Mar 05, 2011 | GE JVM1850 1000 Watts Microwave Oven
Viking 1100 watt Microwave will not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjj
Jan 05, 2010 | Viking VMOC205SS Microwave Oven
1) Fuse
2) Diode
3) Capacitor
4) Transformer
5) Magnetron
Dec 11, 2009 | Samsung Microwave Ovens
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Emerson MW8991SB Microwave Oven Logo
318 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
