Question about Intel Motherboard
Right i need the size or model for the cooling fan that all intelboard mode E210882
  • Intel Master
  • 5,660 Answers
The Heatsink/Fan combo is based on the processor socket used.
After a few search hits, I have seen E210882 on Intel based motherboards, that use two different processor sockets.
The Socket 478, and the LGA 775 processor socket.
The socket for the Socket 478 has the pin holes. The Processor has the pins. (478 of them)
http://en.wikipedia.org/wiki/Socket_478
The socket for the LGA 775 processor socket has the pins. The Processor has the pin holes. (775 of them)
http://en.wikipedia.org/wiki/LGA_775
Identify which processor socket you have, buy accordingly as to the Heatsink/Fan combo.
One example of a Heatsink/Fan combo for an Socket 478 processor socket,
(Only Intel uses the Socket 478 for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=578161&CatId=795
One example of a Heatsink/Fan combo for an LGA 775 processor socket,
(Only Intel uses the LGA 775 socket for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3302824&CatId=1588
Remember to observe Anti-Static Precautions, Thoroughly clean the top of the Processor's case, and aplly fresh new thermal paste.
(A Processor is the most susceptible hardware component to Static shock)
[ Example of thermal paste,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503 ]
If you would like advice on how to properly clean the processor's case, properly apply thermal paste, and/or what Anti-Static Precautions are, post in a Comment.
Posted on Nov 07, 2010
Why doesn't it cool?
If I unplug the Peltier the unit starts right up, the display working again and fans come on . Is Peltier shot ?
I also can't find the 4.5inch fans for unit Fan Model # SD1225S12L. What would happen if I leave Peltier unplugged ??
Dec 17, 2015 | Cuisinart CWC-1600 Private Reserve Wine...
Dell insipirion 530s power light stays orange fan running wild
Hi deb lewis,
the orange power light is your warning that your power supply is going bad. I'd replace the power supply with the same size or larger (preferred)
Best of Luck
Mark
May 11, 2012 | Dell (E210882) Motherboard
Fans keep running high speed on the E210882 motherboard
This may be because the system is running too hot. The fan sits on top of the heatsink which cools the processor. If the heatsink is blocked with dust, the fan will be working harder trying to blow air through the heatsink fins to cool the processor. Open the case and check that the heatsink is clear of dust.
Apr 02, 2012 | Gateway Computers & Internet
High low fan motor
Your main concern is the temperature difference across the indoor coil for both heating and cooling. When you turn your thermostat from auto to on, you are on high speed.
If you have long duct runs and little return air registers then high speed
would help cool the house better. However in the heating mode, you
could lose up to 10degrees by having the high speed setting.
What they installed is sized for your house and the speeds should not have to be changed unless the ductwork is not sized right for the house.
Cooling should be High-Black wire.
Heating should be Low-Red Wire.
400cfm equals a ton of cooling= 1200 sq. foot, For cooling you need
High speed. For heating it is whatever the temperature rise across the
coil is, which is located on the furnace/air handler.
Jul 13, 2010 | Goodman CLQ36AR49 Air Conditioner
What mode on my model hprbo7xc7 is for air
Hi, On all model stats, the mode you want for the fan to cycle off and on with the air conditioning, is cool-auto, not cool-on. With cool on, the indoor fan will continue to run all of the time. In the auto mode, it will cycle on and off.
Sincerely,
Shastalaker7
Jun 27, 2010 | Heating & Cooling
Check fan # 2
Samsung Consumer LCD tv's do not have fans except on the higher end models. The Commercial models do. Yours is a Consumer model. I suspect that you have a DLP tv. In that case replace the Lamp Fan. It is the Larger of the three fans. With the rear cover off, you will see a Blue switch lever on the lower right side of the tv. Hold it in a up position and turn "on" the set with your tv remote. Then look for any fan that is not running. Then order that fan. there is a large fan that cools the Lamp. The other fans are of the same smaller size and one cools the DND chip and the other cools the Ballast.
Jul 04, 2009 | Samsung Televison & Video
Drivers for mother board
did u try windows custum update ? 1st and intell website proably intell chipset
Jan 26, 2008 | Dell (E210882) Motherboard
Intel Motherboard Logo
231 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
