Question about Alpine CDA-7892 CD Player
How do i install it the rite way ?? - Alpine CDA-7892 CD Player
  • 528 Answers
You can go to your local Radio shack , electronics supply store or stereo shop and pick up the proper wire harness for your vehicle as well as an aftermarket stereo installation kit to fit your specific vehicle - both should cost between $30 to $60.00. This will include a color coded wire harness to connect your car's wiring to the stereo and the proper mount and bezel to have a professional looking job. Buy plenty of crimp connectors ( usually 16 to 18 gauge) and follow the directions in the harness kit. Your biggest enemy in this job will be impatience because it is very tedious hooking up the wires 1 at a time. Disconnect your battery before you start to ensure no power surges or short circuit accidents to fry the stereo.
Hope this helps!!
Posted on Nov 07, 2010
  • 87 Answers
You need a dashkit, wireharness and antenna adaptor. It all is vehcial specfic so you need to look in up for the make model and year. Use schoche or metra online to give you the part numbers of the kits some cars will not require the dashkit or the antenna adaptor.
-david
How to clean or remove impellers in sta rite pool pump
remove band clamp then remove the part over the impeller then the reverse screw holding the impeller on then unscrew the impeller regular thread hold the back of the motor shaft take apart remove old install new and re assemble
May 16, 2014 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Pulsing pressure
check for leak at intake fitting
Feb 16, 2014 | Sta Rite STA-RITE WATER PRESSURE SWITCH -...
I have a sta rite heater when pool turns on the heater lights go on threw its cycle but when i go to turn on its like there is no power
does the blower come on? if not, make sure you have the proper voltage plug installed. or the voltage plug may be loose
Aug 23, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
Alpine How To Connect Usb
All your connections are on the rear as is the usb if your able to get up under neath dash and access the back of radio you can get the USB plugged in its a green plug on the drivers side on that model. ipod plug is rite next to it if i remember rite. Go to like Cruthfield type in your model and name and if they have it theyll show you all sides of unit.
Apr 29, 2013 | Alpine Car Audio & Video
I lost mo rite webcam driver please give me driver model_my_352A
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 28, 2011 | Orite MY352 Webcam
I have a sta rite heater installed about a year ago, it is showing Service light on, and it ignites for a couple of minutes then begins to shut down, The gas meter has been changed a couple of times to a...
If this is a propane heater and you have changed the meter that means you have natural gas. A converstion kit is avable and all it is is a washer in the gas line inside the heater. You can buy these but my wholsaler just gives them to me when I get a heater. Get your installer to do this for you first before you buy anything else. Also check the size of your gas pipe to the unit. It need's to be sized to the heater and the run of pipe. You can find this info in your book that came with the heater.
Sep 07, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Spark plugs
open the hood go to the spark plug wires ang get a socket wrench twist them off make sure you get the rite new spark pluges make sure there gauged rite to be gauged it is the distances the spark travles from the metal to the center
Mar 09, 2010 | 2005 Ford Focus
Mounting locations for air springs compressor and tank
just did google search for ride rite air suspension and found complete install instructions & diagrams....do that!!!
Jun 19, 2009 | 2005 Chevrolet Silverado
Alpine CDA-7892 CD Player Logo
163 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
