Question about Toshiba 57H82 57" Rear Projection Television
Toshiba we should start a consumer group. toshiba **** and offered no help with replacing my hyper board either
  • 934 Answers
Just pull the hyper module and send it in for rebuild - then simply reinstall it...
Bill
Premium Technologies
premtech@willapabay.org
Posted on Jun 30, 2008
Toshiba/ 42H81 / hyper board
You can either yrplace your Hyper board, or replace all the serfice mount capacitors in it. The cap replacement fixes this 90% of the time.
May 09, 2012 | Toshiba 42H81 42" Rear Projection...
I have a Toshiba 65H82 television with the wavy line problem. I have read the solutions on this site. It talks about the "hyper board." The list of boards in the service manual does not list a...
Hyper board is located under metal shield mounted on signal board in tv, buy repair kit from HERE and replace capacitors in hyper board to solve wavy picture problem in Toshiba 65H82
Thanks.
Mar 29, 2011 | Televison & Video
Hi I have a Toshibe DLP 46HM95 that I have purchased in 2004. I am having a problem with the picture color. It has a pink/purple/green tint and seems like the connection is trying to go out. I replaced the...
This problems,u have is not the projection lamp problems.The problems,u have it known as convergence problems,it dead.The colors lines R,G,B mis alignment,picture have colors shadows,pictures look like a 3D pics.The Toshiba DLP tvs have a board call a HYPER board,that the Toshiba tvs convergence board.The (HYPER-BOARD)the tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the HYPER-BOARD known as a convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 29, 2010 | Televison & Video
50HDX82 rear projection Flicker/Fuzzy and Vertical Purple Lines
The hyper module itself is not an expensive repair about $70 to $100.00 dollars. The tech will simply be replacing about a dozen 16v/10mf smd caps and re-installing it on the signal board. But that doesn't address what he has to do to get to it and get the hyper board off and back on the signal board and that is a bit time consuming.
What I would suggest is to call around to the various shops and ask what they charge for the hyper module repair and see if you can get an off the cuff estimate for around $250.00 dollars.
If you need help finding some reputable shops try TVrepairpros.com for help in finding some of the best technicians available.
Bill
Jan 09, 2009 | Toshiba 50HDX82 50" Rear Projection...
Shakey screen
Needs to have the hyper module repaired... There are a group of caps on the hyper that need to be replaced... The hyper module is a stand-up board on the left looking in the back of the unit just behind the jack panel... Need to remove it and send in in for rebuild or attempt the repair yourself..
Bill
Jun 12, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 57h81 location of hyper board and remove procedure
Hyper board is located directly behind the input board, this is where all the tv conections are, then they are two tabs soldered from the bottom of the board then it simply unplugs, But replacing all those capacitors on that board can be a little tricky, replace all 10up @16volt caps and that usaly repairs the board
Feb 12, 2008 | Toshiba 57H81 57" Rear Projection...
Tv only watchable through component Toshbia 57H82
this is a known problem with these toshiba tv's, they will do nothing to help you we should form a consumer group and complain to Washington! The part that needs to be replaced is a hyper pcb,pd0637and is available from Tritronics, in Miami Fl.phone #1-800-365-8030.the part cost me $263.00
Dec 06, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57h82 replacing caps on hyper board
trace them with a continunity meter and all will be ok...
Sep 17, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba model 57H81
hyper board is nat made anymoore just replaced 10 10uf caps inside.
Apr 02, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
