Question about SmartDisk FireLite 40 GB Hard Drive
Hi. I have lost my adapter and connectors to connect my smart disk HD to my Macintosh power book (g3 model). The model # on my disk drive is FWFL80-N. Has another # which is JH7X04. Where can I find replacements? Thanks, Becky
    Brigadier General:
  • 10,406 Answers
You could buy a disk-drive-to-USB adapter, and connect the "bare" disk-drive to a USB port on your computer, and then copy all the files onto your computer.
See: http://cgi1.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=190391564434
for under $5.00 for such an adapter.
Or, you could spend about $40 to buy a brand-new enclosure & AC-adapter & cable that is "empty", and then you could "transplant" your 40GB disk-drive into that enclosure, without losing any data on the disk-drive. Then, copy the files, and then remove the disk-drive, and purchase a new, larger, disk-drive, and install that into the new enclosure.
Given that your disk-drive is "only" 40GB, it's probably getting old, and is "out-of-warranty", and thus should be "retired" before it completely fails.
So, the best solution would be to buy a brand-new, much larger, external storage device.
Posted on Nov 07, 2010
Proliant does not boot from raid controller if external SCSI drive is powered on.
Try to disable boot to other device on your bios setting.
Make sure that your Smart Raid is set on the first boot device.
Nov 01, 2011 | HP Compaq ProLiant ML350 G3 Server
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
Part No. 9W2874-582
Sata drives use both 5V and 12V power. The standard SATA connector found on most current power supplies carries both. If you're trying to rig up some temporary power just hit your local PC shop and ask for a Molex to Sata adapter that will connect your old power supply to the new drive or pickup a USB to SATA adapter kit as they usually have there own Sata capable power adapter.
Hope this helps FixYa,
Chris
Oct 21, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Apple Macintosh PowerBook G3 Start-up problem
Your mac doesn't recognize the system folder. Try to find the original boot disks that came with the machine, and see if you can mount the hard disk while booting from the CDs. If you can, I'd backup the data as soon as possible and reinstall the operating system, including a full hard drive reformat. If you can't see the hard drive from the boot cd, another option is to hold down the T key during startup to boot the mac into "target disk mode" - this will allow you to hook up the g3 to another computer as an external hard disk in order to back up the data.
Oct 21, 2009 | Apple PowerBook G3 Mac Notebook
My mac doesn't show the microspot 500gb slim-drive hard drive anywhere...? i've connected the hd with my mac but nothing happens... on the manual i's written, that if i work with macintosh, i should erase...
What model Mac is it? Some earlier models only had USB 1 and they can be problematic when trying to connect a USB2 device.
If you look in the system profiler (go to about this mac and then select More Info) does the drive show there under the USB tab?
Does it show in Disk Utility (in the Utilities Folder) as an external drive?
Oct 15, 2009 | Computers & Internet
Hi, I recently bought your 750GB My Book external drive, which I have connected to a Macintosh G4 desktop computer.  The computer does not recognize the external drive now, although I was previously able...
Be sure to plug the USB connector and the back of the CPU. Then go to Application folder if your running on OS X. Locate the disk utility, then double click it and see if your external drive have been detected. If it is detected try to repair it. and then thats it
Dec 07, 2008 | Western Digital My Book Premium ES...
Have just bought a Verbatim portable hard drive (120GB) and it won't show on my Mac desktop. It works fine on my PC
Make sure your Mac meets these minimum criteria or it won't work.
  • Any Macintosh with built-in FireWire port or a Power Macintosh G3 with a powered PCI 6-pin FireWire adapter
  • Mac OS 8.6 to 9.x; Mac OS X 10.1 or higher
Sep 18, 2008 | Computers & Internet
Toshiba pa3064u-1pcc macintosh
You have to turn on sharing on both computers first, assuming the Toshiba allows it. Your Mac does. Then you can connect it using ethernet or USB. Unless they are both connected to a network, sharing is the only way to go or if it will even work.
Aug 25, 2008 | Toshiba (PA3064U-1PCC) 802.11b Wireless...
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
SmartDisk FireLite 40 GB Hard Drive Logo
176 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
