Hi, i have a advent 7011 laptop that runs really slow. it has a 2.4Ghz processor, 256mb ram 30Gb HD (20.5gb free). i did a fresh XP Home install a few months back but it is still very slow - once an item has been clicked it can take upto 10 secinds to actually do anything. Please help!
Have you tried adding extra RAM?
I've got an Advent 7011 that had 256mg in it. I took it out and replaced it with 1Gb and it works a lot quicker!!
Posted on Jan 03, 2009
  • 3,940 Answers
Most slow portable systems (Once software has been eliminated as a cause) run slowly do to problems with cooling the processor. Possible solutions include:
1. Cleaning out the heatsink fins using canned compressed air by repeated blowing in the intake and exhaust vents.
2. Replacement of a failed or failing CPU cooling fan and/or heatsink (Normally I replace both, as some heatsinks use vacuum tubes and the tubes can lose their seal and become ineffective)
3. RARE: Replacement of the processor
4. Just in case you havent checked these SW/Firmware options. In the BIOS make sure the CPU is running in a NORMAL mode (Some have a compatible mode which slows the processor dramatically) Also ensure the power management settings in Windows are set to Maximum Performance/ALWAYS ON
Posted on Jun 15, 2008
My dell Inspiron 1100 runs slow
Change the RAM. for a good one. And set it up to Windows Clasic View.
Check vent.. - is it clean, and in good condition ? Cream between Processor and radiator...- isn't dry?
Oct 14, 2012 | Dell Inspiron 1100 Laptop/notebook
Have a toshiba a10 and a vizio hdtv, what cable do I need to connect the two
Hi.
You don't say what you intend to do once the 2 devices are connected. I am going to assume that you just want to use the vizio hdtv as a large external monitor.
The laptop's vga (15-pin blue or black D-shaped) port can connect direct to the hdtv via it's blue vga (15-pin blue D-shaped) port.
However, your toshiba a10 laptop is relatively old, discoontinued technology with (in original specification) low RAM (256mb ddr), a single, slow processor (2.2ghz celeron) and slow (4300rpm), small hard drive (30gb), with limited, low level vga graphics capability, running xp home edition operating system. VGA is a slow analogue video technology.
To get the full benefit of the hdtv, which is almost state-of-the-art, you need a laptop with a fast dual or quad core processor, 3-4gb ddr3 RAM, 320-500gb 5400-7200rpm or solid state HDD, running the latest windows 7 operating system. Such a laptop would have hdmi ports and powerful, fast, state-of-the-art graphics capability.
A new laptop would unlock the full spectrum of , high definition video, high speed audio-visual streaming, fast video-editing, multimedia functionality between the two devices.
For your current laptop you need a male-to-male 15-pin, D-Sub VGA cable.
For the recommended or a similar, modern laptop you would need an HDMI cable.
Hope this helps.
Aug 02, 2011 | Computers & Internet
Does windows 7 run fast on via processor?
Yes, Windows 7 should run OK on your PC
Jun 27, 2009 | Computers & Internet
I only need a sound driver for this Advent 7011 laptop.all the driver is installed expect for only Multimedia Audio Controller. Under the laptop. i find this number: N35AS1.
http//www.google.com and type in the search area, "dounload advent 7011 sound driver type n35as1 it will bring the options of dounloads, donuload and install
Apr 01, 2009 | Advent 4211c Notebook
Hd dvd codec
Install (Ahead) Nero CD burning software, ver 8 or later. It has the necessary codec....sodeep
Mar 20, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
Install Win XP SP 2
Yes you can, Do I recomend it, no, Why?
Windows easily uses up to 756MB of RAM to run the O/S alone but can run at a minimum of 512MB.
I have personally seen it run on as low as a 900Mhz processor, 256MB of RAM and on a 10 gig hard drive.
If you decide to install windows XP on the specs you describe above please note the following.
1. System will be very slow and have lengthy start up times.
2. Applications may crash or take a long time to open.
3. With all the updates for WinXP you will easily use 8 gigs for installing XP and its updates. Not to mention whatever software you will use/install.
4. On a system with those low specs, you probably have a low end video card whcih may result in: A. chooppy windows, screen freezing, system crashes and lock ups, low video graphics all around.
I would probably go with windows 2000 instead. If your bent on having XP, at least upgrade the RAM to as much as possible. Then install windows and only install the programs you really need, remove any other junk.
Hope this is of some help to you, good luck
Feb 17, 2009 | Dell Inspiron 4000 Notebook
Slowness of the Laptop
The laptop is not redundant. Go to Crucial and go through their memory scan. XP can run on 256mb ram but not well. You will get more years out of the computer with more ram installed.
Dec 10, 2008 | HP Compaq nx6110 Notebook
Emachine sp2 prob
BIOS is unlikely to fail from a software fix such as SP2 but you may have too little ram or too slow of a processor to handle changes.
You may have to do a complete reinstallation of XP to set things right and then try the SP2 upgrade again.
Windows is unfortunately sometimes infuriatingly cranky and may require repeated installation before settling down.
Also, eMachines may have tweaked their version of XP in a way not compatible with SP2.
Check their website or MS Knowledge Base for clues.
Apr 29, 2008 | Computers & Internet
Fisher-Price Digital Arts and Crafts Studio
Hi all frustrated fokes out there who still have problems installing and running this new product.
We bought this too for our dissabled daughter and have found it will not work on her pc , but will work on all the others in the house ..grrrrrrrrrr...lol.
What i did find was you must have net framework 1.1 installed and updated min for the software to install . other wise it will try to install the net framework 2.0 from the disk. the net framework 2.0 is an update from 1.1 and much software that requires net usage needs this base framework.
this is the spec of the pc it do work on ...and yer it well over the min requirement
System Information
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+, MMX, 3DNow (2 CPUs), ~2.4GHz
Memory: 2046MB RAM
Page File: 392MB used, 3547MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
The pc it will not work on only has 256mb memory,and a 128mb graphics card. Buy the time windows boots up and all the other programs also are running there is not enought memory spare to even launch the system. So a min of 512mb installed is required on a xp system
Another point i found was when i inserted the usb windows did not register it so following the install instruction very carefully ..eg start to installing the software and when it says to insert the usb cable do so then .
When you do get it working , your keyboard and mouse will not function, only ctrl+Alt+del will to interrupt the program . The pen will be your mouse thought i'd better say that cos it fooled me at first ..lol ..
Hope this helps ...
Dec 26, 2007 | Adobe Photoshop 7.0 for PC
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
