Question about Palm Treo 650 Handheld
Screen doesnt wake up
Hello.. hoping you can shed some light here.. my 650 screen will not wake up. i thought maybe i had a software issue so i did a soft-reset; hard-reset and when neither of those helped I ran a zero-out reset. after that the screen came back to live but it is unstable; fading in and out and displaying in a manner similar to signal interference on a TV.
The phone was bought used on ebay a few months ago in good condition and has not been abused to my knowledge.
It has been suggested that i check the cable connections inside the casing which i can do once i get the right screwdriver to fit it. Meanwhile I wanted to ask you guys if this sounds familiar and if I should just consider this phone a lemon.
Thanks a bunch!
Matt
matthesley@gmail.com
  • mh11 Jun 16, 2008
    thanks for the response.. i have it working again. i did the following per advice from coolguy08 at fixya:
    1. zero-out reset
    2. remove & replace battery
    3. upgrade firmware
    4. soft reset
    i also opened the device and gently pressed the screen cable connections.
    after doing all the above the screen woke up & its been fine ever since.
    thanks a bunch for the help.
    matt
  • mh11 Jun 16, 2008
    phone is working again. thanks!
    Sergeant:
    Champion:
  • 248 Answers
Most common lcd problems are usually caused by cable connections or if not try changing your battery pack....
Posted on Jun 15, 2008
Why does my Sony Cybershot DSCW370 Turn on but the LCD screen doesnt stay on????
You might have the Power Save Mode on, if camera wakes up after you depress the shutter button and the screen lights up, then more than likely you have the Power Save Mode on? The settings come in 3 values, screen turns off after 30 seconds, next setting is screen off after 60 seconds. Go the the cameras menu and then navigate to Main Settings, scroll down until you find Power Save Mode and adjust it to standard, hope this helps?
Sep 29, 2014 | Sony Cameras
My brand new garmin nuvi 600/650 stop"talking" all of a sudden..no sound at all; however the headphone is working...how to change the microphone?. Also, the same day it was a message on the screen to...
Brand new device with a manufacturer provided upgrade and it doesnt work? - return it, or contact Garmin directly for a fix. If you start fooling with it, they will not help you. http://www.garmin.com/garmin/cms/site/us
Jan 17, 2010 | Garmin nuvi 650 GPS Receiver
I cannot use the touchscreen for the upperhalf of the iphone
Hello.
Found some info online:
Try the following:
  • Reset your iPhone Sometimes, dead spots on the screen are merely the result of frozen applications or an unresponsive interface rather than actual hardware failure. Press and hold the Sleep/Wake button (on the top of the unit) and the Home button simultaneously for several seconds until the Apple logo appears and check for persistence of the issue.
  • Clean the screen A glaze of any foreign substance can cause operational difficulties for the iPhone's screen. Clean the screen with the cleaning cloth that came in the box with the iPhone.
  • Restore your iPhone As a last resort, try restoring. This can remove lingering software issues that might be causing a lack of screen response. To perform a restore, Connect your iPhone to your Mac or PC and, in iTunes, click the Restore button under the Summary tab. Please NOTE: Restoring the phone will erase contacts, calendars, photos and other data on the phone, but will restore automatically backed-up information including text messages, notes, call history, contact favorites, sound settings, widget settings, etc.
If you're still having problems, contact Apple for repair.
Hope this helps.
Jan 11, 2010 | Apple iPhone Smartphone
Flat screen tv winter storage
HELLO
Your TV will be fine as long as it is kept at room temperature indoors and not inside a shed or similar outbuilding. Much warmer in a house, probably near freezing in a wooden shed.
Hope this helps you (:-)
Oct 17, 2009 | RCA L32HD31 32 in. LCD HDTV
Screen does wake with computer
go 2 control panel and select power management and configre ur monitor time when it go to sleep mode. thanks
Jul 29, 2009 | Computers & Internet
Screen is dimmed and flashing
It's the #1 plaguing issue with flat panel TVs in all brands. If the red light on the TV is blinking when this happens, It should be an error trouble code.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. The Backlight Board supplies power to the screen in different sections. With a 47" screen, it maybe divided into 10 to 12 sections. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 14, 2009 | Philips Televison & Video
Screen flickering problem in w830i
No, it is probably the fact that the phone is from so far away, it obviously was not made for use in the US so the signals emitted by cell towers here can affect that or the other thing is the phone may just be defective and it may need to be replaced but seeing as how you got in from India it doesn't look like that is going to happen. My suggestion: get a new phone, and quick before you wake up one day and your phone won't work at all. Hope I"ve helped, sorry your having so much trouble with this. Hope i've helped shed some "light" on your issue. :)
Mar 31, 2009 | Sony Ericsson W830i Cellular Phone
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Jun 24, 2008 | Palm Treo 650 Handheld
I can't "wake" my aspire 3628 ANWXCi from standby
Go to the Acer website and download latest e manager software drivers, they may be corrupt. http://www.acer.co.uk/acereuro/page74.do?UserCtxParam=0&GroupCtxParam=0&dctx1=17&CountryISOCtxParam=UK&LanguageISOCtxParam=en&crc=2553782219
Jan 15, 2007 | Acer Aspire Notebook PC
Palm Treo 650 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
