Question about Asrock N68S Ucc Socket AM2+ GeForce 7025 DDR2 RAID AVL mATX Motherboard
New build Asrock N68-S UCC. System boots successfully from firmware DOS(?). BIOS shows that HD and SATA DVD drive recognized. Boot sequence set up for boot from DVD drive as device 1. Drive's read light suggests that attempt made to boot from DVD but fails. Message comes up to create SATA driver diskette Diskette created and then attempt to boot from diskette. No success. What to do next
3 Suggested Answers
  • 8 Answers
SOURCE: how do i upgrade my built in vga without buying
you download crack version of your software by filehippo.com or utorrent.com.
dont upgrade online, it eill damage you software.
Posted on Feb 15, 2011
  • 14 Answers
SOURCE: asrock N68-S3 UCC Windows 7 64
http://www.asrock.com/mb/download.asp?Model=N68-S3%20UCC&o=All
Try re-installing the drivers and see if the computer picks up the hardware on your next reboot. If you're having trouble getting audio from the front panel of your desktop, try using the back panel. If it works then the cabling inside of the computer to the front panel might have become detached.
Posted on Oct 26, 2011
BDR206bk/1 Bluray Burner?
It shouldnt need a driver to boot from it on a modern system, as far as i know... although to be honest never tried an install via a blueray drive.
I assume you have already set the boot sequence so this drive should boot first, from within the BIOS.
You can access the BIOS usually by pressing repeatedly either the F2, F10 or delete key, depending on the system, as soon as you power on the system. within there, often under "advanced settings", look for boot sequence... and make sure this drive is listed first... then save changes and exit...
I know there are some issues depending on which sata port u are using on the mainboard... try changing the cable to another sata port. if the sata port is an ODD port, it is often only enabled when ACHI is also enabled from within the BIOS. so, id try changing the sata port the drive is connected to...
a couple of things to try first...
hope this info helps.
May 19, 2012 | Pioneer BDR205 Bluray Burner
Having trouble booting two Raid-0 discs on Asrock Z77 Ex4 UEFI
RAID implementations will vary from controller to controller, and even from bios to bios revision or version for the same controllers.
You should "image" the raid on the old board, then delete the raid on the old system.
In the new system, you need to treat these drives like they are new, blank hard disks. Any partitions will need to be removed, and the RAID created on the new board. Once this is done, you can use your partition imaging software to drop the data back onto the new RAID partition. Seagate I believe has imaging software available in Seatools, or you can use something like Acronis True Image or GHOST.
May 16, 2012 | Computers & Internet
I have an asrock p67 extream4 it sees the optical sata drive in the bios but will not boot from it. I have the dvd drive first for boot. What should be the bios settings to boot from the optical drive?
In the Advanced Boot settings of the BIOS you will see a general boot order setting and then there are 2 others: for the order of the optical units and for the order of the hard disks.
Open the setting for the optical units and put the SATA one first - the IDE one is there first by default.
Jun 11, 2011 | Asrock Computers & Internet
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Hard disk not detecting
It is very likely that your motherboard is not capable of handling large HDDs. Too bad, friend. Use a smaller one, or may be two of them.
Sep 08, 2009 | Asrock K8Upgrade-VM800 Motherboard
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Selecting Boot Device
If you want to boot from the IDE HD drive then you should get into BIOS and set it as the first boot device, followed by your SATA drive and CD drive. That should do the trick.
Hope this helps,
Sai.
Feb 03, 2009 | Intel D945GCCR Motherboard
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
Asrock N68S Ucc Socket AM2+ GeForce 7025 DDR2 RAID AVL mATX Motherboard Logo
148 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
