Question about Pioneer Voyager 4000 HD-DVR
I unplugged my Pioneer Voyager HDTV set top unit. When I plugged it back in again, it sayed "Initializing please wait". It sat like that for a while and then froze. Now when I turn it on and try to get to any channel, it just says "no string". I can't seem to get any channels on it.
  • Pioneer Master
  • 8,457 Answers
The dawn thing having problems with it programming softwares not rebooting.U renting this thing from the satalites or cables compannies?Return it ask for a replacement unit.
Posted on Nov 07, 2010
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
I have a HP 44" Z3100 and after switching and saying "Initializing, please wait" it gives error 79-04 " Help needed urgently please!!!
Firmware issue:
1. Cancel all pending/que jobs
2. Disable nesting option
3. Dis connect data cable, restart the machine.. check...
4. Up load latest firmware.( read carefully read me file before up loading the firmware)
Jan 18, 2013 | HP DesignJet 1050c InkJet Printer
Pioneer PDP5050Hd -- Starting up. Please Wait.
Try unplugging set for a while and also disconnect all cables, seen a few where something on one specific .1 type channel confuses the set and locks it up, if you get it working go in the menu and delete that channel.
Aug 28, 2012 | Televison & Video
Screen says "initializing..." and won't do
turn off then wait 2 min, then turn back on.
Aug 02, 2011 | HP PSC 1610v All-in-One Printer
Display is stuck on "initializing..."
1. disconnect it from any other devices.
2. turn the printer off and unplug it.
3. plug it back in and try again.
Dec 16, 2010 | HP PSC 1610 All-In-One InkJet Printer
Hooking sat to car stereo
that plug at the back is not for sat radio. It is for use with steering wheel controls. You have the blue plug at rear of stereo and that is the plug for sat radio. Ericson electronics is contracted to build the sat compatible units that wire into this radio through the blue. plug. if you are using 3.5 plug audio control from a portable sat receiver, the you will need to buy an aux input cable for your stereo..
Sep 25, 2009 | Pioneer DEH-P3700MP CD/MP3/WMA/WAV...
Disc error
I have a 08 Cherokee SRT8 that did the same thing. I took my radio out and unplug it from the back to disable it from getting power. Waited a min then plug it back up. Note: if it does it again, replace head unit. Unit is going bad. I replaced mine w/ a aftermarket Pioneer double din with navi using all the factor plugging and steering controls.
Mar 31, 2017 | Jeep (82208269) 6-Disc CD Changer
Pioneer DVR-633H-S hard drive problem
do the Reset to factotry settings,hold two buttons same time {STOPand STANDBY}on front off your unit and unplaged the power from the wall same time.wait like 5minutes,and pluged back the power,this my work,did work for me.
Dec 10, 2007 | Pioneer DVR-633H-S
Pioneer Voyager 4000 HD-DVR Logo
155 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
