Where is cr2032 battery location, which part should open cover to replace it ? thanks.
  • joecoolvette
    joecoolvette Nov 07, 2010
    What motherboard is it, (Manufacturer name and Model Number), or what is the computer manufacturer name, and Model Number? (Back of a desktop computer next to the Windows Product Key, or up on the side of the tower. On the bottom of a laptop)
  • 32,281 Answers
Open the case or cover on the side where the expansion cards are installed. The CR 2032 is lithium 3 volt BIOS battery, you can't miss it. It is 20 mm diameter and it is shiny.
Posted on Nov 07, 2010
Www ehow com
Cmos battery is usually a 3 V button battery, there are variety of different brands so you need to open and check it.
eBay: ACER ASPIRE 7741G 334G50 MS2309 CMOS BATTERY - 476
http://www.ebay.com.au/itm/ACER-ASPIRE-7741G-334G50-MS2309-CMOS-BATTERY-476-/161408573087?pt=AU_Components&hash=item2594b35e9f&_uhb=1
2035, 2032 can be bought from any super market or hardware store. Need to open the PC, locate the battery, which is normally clipped to the mother board. Use a small screw driver and lift out. If battery is soldered to the mother board then need to access under the board and de-solder carefully without damaging the tracks.
2032: CR2032 CR 2032 5004LC 3V 3 Volt button cell lithium battery for CMOS
http://www.ebay.com.au/itm/CR2032-CR-2032-5004LC-3V-3-Volt-button-cell-lithium-battery-for-CMOS-/271586313364?pt=AU_Electronics_Batteries_Chargers&hash=item3f3bce4494&_uhb=1
solder types: SONY CR2032 3V SOLDER TAB Pin battery with soldering tag for CMOS Bios PLC new
http://www.ebay.com.au/itm/SONY-CR2032-3V-SOLDER-TAB-Pin-battery-with-soldering-tag-for-CMOS-Bios-PLC-new-/271570170168?pt=US_Single_Use_Batteries&hash=item3f3ad7f138&_uhb=1
Aug 30, 2014 | Acer Aspire Z5771-UR31P - All-in-one - 1 x...
Cmos battery starting problem
you must open your computer case (left cover) and replace the type CR2032 battery installed on your motherboard
Aug 28, 2012 | Dell Dimension 3100 PC Desktop
Cmos checksum bad Chassis Intruded Fatal Error System Halted!
To remove CMOS Checksum error, you have to remove the coin cell battery from the motherboard and install a fresh one. A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
For Chasis Intrusion msg, go to the BIOS (when prompted, press the Function Key at the system startup) and locate the option of chasis intrusion option and disable it, save settings. Commonly, to enter the BIOS you have to press F2, F10 or DEL Key, depending up the make/ model of the PC you have.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 08, 2011 | Computers & Internet
Website's security certificate problems
There is nothing to worry about. This issue is just because of the date settings on your PC are invalid. Adjust the date (to current date/month/year) and you would be able to log-on normally. This may have been caused due to incorrect settings or the worn out CMOS/RTC Coin cell Battery.
CreativeTECH
Jun 29, 2011 | Computers & Internet
Does any batteries support any sort of motherboards
Any brand of CMOS battery will work on any motherboards as long as it has the same size. Make sure to bring your CMOS battery when buying a new to make sure the size is the same.
Your feedback is greatly appreciated. Thank you for using FIXYA.
May 04, 2011 | Compaq (203966-001) Motherboard
A problem with the pass word in the start
The main board has a battery commonly used as CR2032. Extract it from it location during 30 seconds once you have taken out the main battery and power from your Laptop.
Install again the CR2032 and it will be the manufacturer's password.
Thanks.
Feb 28, 2011 | LG Computers & Internet
HOW TO CHANGE BATTERIE FROM TG 450 FRANKLIN
1. Turn the unit over. 2. Gently push down on the tab under the battery cover and flip the unit to allow the cover to drop out. Do not force the door open. 3. Remove the old batteries. Use a paper clip if necessary to release them. 4. Install the new batteries (two CR2032 three volt batteries) with the positive side (+) facing up. 5. Replace the battery cover.
Feb 24, 2011 | Franklin TES-118 Translator
Replace hp compaq dc5100 sff c mos battery
open the side cover of cpu and you will see inside motherboard ther is one lithium cr2032 battery is there that is cmos battery.
Jan 14, 2010 | Office Equipment & Supplies
I need to replace the battery on my centerpoint scope
I'm not sure which model you have but the most common battery location is under the reticle switch on the ocular lens housing, you have to hold the base of the switch with one hand and turn off the cover with a coin in the other hand. The most common battery for these scopes is a CR2032 button style battery.
Hope this helps, Mark the Gunsmith
Please leave feedback, Thanks!
Dec 05, 2009 | Centerpoint Technologies CenterPoint AR22...
Remove bateries from audi q7 remote and required disassembly.??
- Buy a CR2032 3V battery
- Pry open the battery cover on the remote using a flat head screw driver or a table knife. The pivot point is the chain ring holder opposite to the key.
- Replace battery
Jun 03, 2009 | 2009 Audi Q7
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
