Question about GE WHSE5240D ENERGY STAR Super Plus 3.2 cu. ft. Capacity Washer
My Kleenmaid LWK74 washing machine won't agitate on the high speed settings (it only agitates on the 'Delicates' setting where the agitator goes slow). Is this a timer problem or motor problem
SOURCE: Inglis Washing Machine agitator not working right
replaced timer problem solved thanks
Posted on Mar 30, 2008
  • 38 Answers
SOURCE: washing machine
take the top piece off by hand. Below that should be a plastic cover hiding a bolt. Lift up this plastic cover and remove bolt. Lift agitator up. Might have to wiggle it a bit.
Posted on Jun 22, 2008
SOURCE: kleenmaid washing machine
HOW DO I REMOVE THE AGITATOR
Posted on Aug 12, 2008
SOURCE: kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Posted on Dec 30, 2008
  • 69 Answers
SOURCE: How do you remove agitator in Kleenmaid KAW793?
The agitator just pulls off- they can be very tight!! You need to get your fingers under each side of agitator and pull up. Kleenmaid do have a special tool to make this easier, but I have always managed to pull them out by hand with a good firm sharp pull upwards. To refit, just put it over the drive bell ( the plastic thing underneath agitator) and give it bit of a whack to clip it on. Good luck!!
Posted on Aug 24, 2009
Testimonial: "Thanks for your help - it worked!"
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
How do I remove the agitator on my Speed Queen AA4211WE? There's no cap! It all appears to be one piece.
I just did that. Just pull up really hard. Now.. how to get that other thing off to pull the tub, I can't figure out, all bolts are removed.
Jul 27, 2010 | Speed Queen AWS45NW Top Load Washer
Material chord lodged around agitator of kleenmaid KAW393 washer
sorry to saybut you would probley need to stripp down most of the unit...to remove chord.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
The agitator is barely moving - I am not sure if is fully engaging during the wash cycle? How can I check it out?
If the agitator is working it will move slightly, then back - over and over again and cause the water to, well, agitate.
If you have the machine set to delicates it might not come on full force.
Usually you can check it out by opening the lid during a wash cycle.
If it's barely moving then you might have drive/belt issue.
Dec 07, 2009 | Whirlpool LSQ8000 Top Load Washer
Kenmore washer aggiates slower than when new. is
Usually, there are two agitator modes. A Normal ("Fast") mode, and a delicates ("Slow") mode. Put washer in 'delicates' cycle and see if the agitator slows down even further. If it stays at same speed as in perma press or 'normal' mode, then there is an open in the circuit betwixt the controller dial and the agitator control.
Feb 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
#awm693w,removing agitator to replace seals
Unscew the cap on the top of the agitator, then hit it back and forth with your hand and it will break loose. I just did it to mine today and it has not been of for twenty years.
Feb 02, 2009 | Speed Queen AWS75NW Top Load Washer
Washing machine
This may be a little late, but it may assist someone else. On my Kleenmaid top loader I found the agitator has clips at the bottom of agitator that clip over a drive hub at the bottom of the "tub" . All you have to do is gently prise it up using your fingers between the bottom of the agitator and the bottom of the tub.
Paul
Jun 21, 2008 | Washing Machines
Kleenmaid washing machine
This may be a little late, but it may assist someone else. On my Kleenmaid (KAW693W) top loader I found the agitator has clips at the bottom of agitator that clip over a drive hub at the bottom of the "tub" . All you have to do is gently prise it up using your fingers between the bottom of the agitator and the bottom of the tub.
Paul
Apr 06, 2008 | Washing Machines
washing machine will not aggitate will do the rest
Mar 27, 2008 | GE WBSR3140DW Top Load Washer
Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Nov 19, 2006 | Kenmore 24902 Top Load Washer
GE WHSE5240D ENERGY STAR Super Plus 3.2 cu. ft. Capacity Washer Logo
136 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
