Question about GE DBSR453EBWW Electric Dryer
Ge dryer wont stay running
When you turn the start switch it runs, but as soon as you let go it will stop. it only stays running if you hold the switch in the start position.
    Genius:
  • 1,122 Answers
Start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Posted on Jun 15, 2008
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
I have a Candy GOU218 when I push the start button it does start the dryer but as soon as I release my finger from the button it stops, It started doing it around a week ago so I had to push and hold
There are push to start circuits used for motors and then there are holding circuits that keep the unit running. This way the dryer stops if the circuit is open due to high temperature or end of the cycle. It seems as if the holding circuit (could be a rotary switch that stays closed while the dryer is running) or a holding circuit relay (stays closed until circuit is broken by the control) has failed.
Jan 09, 2014 | Candy Dryers
Problem with my GE dryer mod: DBSR453EB1CC. Tried turning it on, and would stay on. As soon as you let the switch go. It shuts off. While its on the tumbler doesn't move. I would appreciate any advice....
That sounds very typical of a broken belt. GE dryers use a belt switch that will cause exactly as your describing...the motor will run as long as holding the start switch and as soon as you release it the motor will stop if the belt switch is not satisfied that the belt is in place...so it again sound very much like the belt is broken.
The part number for the belt is WE12M29 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
Sep 23, 2011 | GE Dryers
I have a GE Profile Prodigy eletric dryer that wont start. When I turn the switch it hums and stops when I let go of the switch, but won't start. Is that a switch problem or motor? How do I tell?
That sounds like to me the drum belt is broken..GE dryer use a belt switch that if the belt is broke will perform exactly as you describe ..as long as holding the start switch the motor will run and as soon as you release the start switch the motor will stop.
To check for a broken belt remove the top by removing the 2 phillips headed screws inside of the door at the top of it and pull off the top to see if the belt is in place and attached to the drum..if no belt seen when top off its broken and laying down in the base frame
GENE
Aug 28, 2011 | Dryers
Not sure of model but dryer does not stay running when switch is released. As long as you hold switch on it runs and when you release it shuts off. Suggestions?
Check the belt is not broken . If the drum turns when you start it then either the belt switch is bad or the motor switch is not working because it is bad or the motor may be full of lint.
Nov 17, 2010 | GE DBXR463EDWW Electric Dryer
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
I had the same problem with my kemore. Thank goodness I still had it under warranty.
The tech said the door latch was just slightly ajar. This is common he said that when we take clothes out we let the door close to hard or gets ajar for leaning in to take clothes out.
He readjusted it and I have never had a problem with it again.
Hope this helps
Sep 26, 2009 | GE DBSR453EBWW Electric Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Jan 06, 2008 | Dryers
GE DBSR453EBWW Electric Dryer Logo
532 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a GE Dryer Expert? Answer questions, earn points and help others
