Question about Garden
The primer bubble on my weedeater has a hole in
  • 297 Answers
You need to replace it. It depends on the type of carburetor you have as to the type of primmer you need. Its not hard to replace. Let me know the make and model of trimmer you have and i can help you determine which one you need.
Posted on Nov 07, 2010
Why my weedeater idle to high and why air bubble in the primer bulb?
Its not un common to have air in the primer bulb, Check for a possible air leak in the system. This will make the saw idle higher than normal if its sucking air from elsewhere.
May 19, 2016 | Garden
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
I have a Husqvarna 455 about 2 years old. At about 1 year point it would no longer start using the primer pump button on the side when cold. If I take off the air cleaner and give it a a shot of gas down...
Your seeing the problem. Air in the fuel lines usually caused by a cracked fuel line or a pin hole in the primer bulb. Until you can stop the air bubbles by either replacing the actual primer bulb or fuel lines your always going to have the hard to start problem. This can also cause the engine to run lean at high RPM settings and eventually burn a hole in the piston. You should repair the fuel problem ASAP. If you do not find any fuel line / primer bulb problems then it is time to start looking at the carb diaphram.
Thanks for choosing FixYa,
Kelly
Oct 08, 2010 | Husqvarna Chain Saw 20" Bar
Hi there,i have a mcculloch tm210 petrol strimmer and the problem is that it will not start,i have noticed that the fuel primer bubble dose not come back out.please can you advise.
clogged fuel line or carberator. my weedeater did this at the first of the season. i took off both lines going to the gas tank and blew on each line separately while holding throttle open on carberator. i felt the clog go thru and put back together, poured a little gas in intake and it started right up and the primer worked right. good luck
Jul 03, 2010 | Garden
I just replaced a rotten fuel line on a craftsman 23cc weedeater, but when i push the primer bubble no gas goes in it. There are no holes i checked. Is there a anything else i could check for problems?
With your cover off so you can see the fuel line, see if you have any bubbles come through.If you see bubbles in the fuel line,when you pull starter rope,you have a line sucking air.
Aug 29, 2009 | Craftsman Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
