Question about Kenmore 64892 Electric Dryer
Kenmore terminal block
I cannot losten the screws on my kenmore dryer terminal block
  • Anonymous Mar 13, 2014
    I have tried a 10-24 and a 5mm.......neither work
    Genius:
  • 1,122 Answers
Get some wd 40,spray on all 3 screws,tap eash screw lighty with screw driver and hammer then try to remove screws,also you can remove the blockscrew on each side and pull it out and get a btter grip on it,let me know-mike
Posted on Jun 15, 2008
What type of screws do I need for a Kenmore 80 series dryer power cord (where the three screws hold the wire to the terminal)
They are machine screws. Remove the terminal block and take it to the hardware store to match the size of the "lugs." Terminal Block 5304409888
Oct 14, 2016 | Kenmore Dryers
Where is the dryer grounding screw?
The dryer cord connects to the dryer at the terminal block. On the terminal block is where the ground for the machine is located.
May 21, 2012 | Kenmore Dryers
Want to switch a 4 prong plug to a 3 prong plug on a kenmore 90 series elec. dryer
ok,, easy one,, unplug, take the cover off of the terminal cover,, take your old cord off, on the 4 prong you will have a red, black, white,and green wire,, matche the colors up red on right, white in middle, black on left, the green wire will go on a green screw that is near the terminal block with a white wire going to it, take the white wire off and put it with the white wire on the terminal block,, screw the green wire to the green screw,, and relpace cove and your done
Jan 19, 2011 | Kenmore Dryers
Need to replace 4 prong cord with a 3 prong cord on a new 500 series dryer.
On the back of the dryer, remove the screw(s) that hold the access cover to the back panel that cover the terminal block where the cord goes through the back panel and connects to the wiring terminal power block, loosen the two screws on the cord clamp the clamp it to the back of the dryer just enough to release the cord, remove the four nuts / screws that are connecting the 4 wires from the cord to the terminal block and or the back of the dryer,with the new 3 wire cord just match the colors on the terminal block with the same color wires that are connected to the other side of the terminal block, red,black on the outer most terminals and the white or green to the middle terminal, IT IS IMPORTANT THAT YOU PLACE A JUMPER WIRE/STRAP FROM THE MIDDLE TERMINAL WHERE THE WHITE OR GREEN WIRE CONNECTS TO THE TERMINAL BLOCK OVER TO THE CASE/CABINET OF THE DRYER, THIS CAN CONNECT TO THE CASE AT ANY AVAILABLE SCREW NEAR THE TERMINAL BLOCK! In short this means that the neutral and ground of the dryer must be connected together in a 3 wire set-up.
GOOD LUCK!
Aug 21, 2010 | Kenmore 500 6952 Dryer
No heat, but dryer turns.
There are three common causes of a dryer not heating. First is a busted heating element. Second, the thermal cut-off has blown. Third, the high limit thermostat is not working.
Disconnect power to the machine and remove the screws at the bottom of the lower front access panel (toe panel) holding it in place. Pull the panel down and off the cabinet. You now have access to the heating circuit.
Remove the heater shield by removing its mounting screw and pulling it off the heater housing.
The heater terminal block is located at the left opening of the heater housing. Disconnect the wire from one of the heater terminals and measure the resistance of the heating element using an ohmmeter set to X1. The resistance should read 7.8 -11.8 ohms. Replace the heating element if the resistance reads open.
Disconnect the wires from the terminals of the heating element and remove the screw securing it to the heater housing. Slide the busted heating element out of the housing and install the new heating element. Secure it with the screw and put the terminal block in place. Connect the heater wires and reinstall the heater shield.
Slide the lower front access panel up into the cabinet and secure it with the screws.
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
What type of screw is needed to attach the electrical cord on the back of a dryer
if it is old dryer best use a new terminal block(comes with screws)
Aug 13, 2009 | Kenmore 400 6942 Dryer
Need to hook up new plug
Red on one side of terminal block, white in middle, red on other side. The green is attached to outside using screw to to top left of terminal block compartment on outside of cabinet. Hope this helps!
May 18, 2009 | Kenmore 62602 Electric Dryer
Electric dryer no heat and eletricut
ck where ac cord is attached to dryer suspect burnt connections on terminal block ..or loose wire touching cabinet if block is burnt probably due to loose connection when screws were not tightened during install
Nov 20, 2008 | Kenmore 73952 Gas Dryer
Kenmore dryer elite
IF THE WIRES ARE RED, BLACK, WHITE, AND GREEN,
THE WHITE WIRE GOES TO THE CENTER TERMINAL.
THE GREEN WIRE ATTACHES TO A GROUND SCREW ON THE BACK OF THE DRYER. UNHOOK THE WIRE GOING FROM THE CENTER TERMINAL TO THE GROUND SCREW TO ISOLATE THE ELECTRICAL NEUTRAL FROM EARTH GROUND ( THE WHITE WIRE FROM THE GREEN ONE)
THE RED AND BLACK WIRES GO ON THE LEFT AND RIGHT OUTER TERMINALS ON THE TERMINAL BLOCK. THOSE TWO ARE INTERCHANGABLE.
Apr 10, 2008 | Kenmore 63942 Dryer
Kenmore 64892 Electric Dryer Logo
137 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
