Question about Honeywell Programmable Thermostat Heater
How do I switch the honeywell pro4000 thermostat from reading in Fahrenheit to Celsius?
  • Honeywell Master
  • 43,501 Answers
Hi, The procedure is fairly simple.... the easiest way is for you to look up the manual and have the proper steps right in front of you...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Nov 07, 2010
Testimonial: "thanx"
Need to change thermostat from Celsius to Fahrenheit
The first link is operators manual.
The second is installation and contains the procedure to set many functions including the display temperature.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2577ES.pdf
See page 15 function set 14. This sets F or C temperature
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2578ES.pdf
hope this helps?
Jun 23, 2017 | Honeywell Heating & Cooling
How to change Honeywell TH3210d1004 thermostat from Celsius to farenheit
Press and hold up and down temp buttons together to enter settings menu. Then press up to option 14. Press down to change to option 0 (Fahrenheit). 1 is Celsius. Press up and down together to save and exit. Good Luck!!
Apr 21, 2017 | Honeywell Heating & Cooling
Thermostat changed to Celsius without out us changing it. We have had this thermostat for several years without any problems. Reviewed the manual and checked to see if the original install was set...
Check the dip switch (3) it should be in the on position...It may have moved when you mounted the thermostat on the base. Also check batteries you are using...long life alkaline only.
Feb 25, 2015 | Honeywell CT3200 5-2 Day Electronic...
How to change Celsius to Fahrenheit on a pzs
You can do this during the setup of the thermostat.
1-800-honeywell
www.honeywell.com,
Dec 13, 2013 | Honeywell Programmable Thermostat Heater
How do I switch the honeywell RTH4300B thermostat from reading in Fahrenheit to Celsius?
To start you have to push and hold the up and down buttons simultaneously until the screen displays "setup" across the top. There will be a number on the left, and a number in the right. Press the UP arrow until the number on the left reads 14, The number on the right should read 0. Press the DOWN arrow to change it to 1. Once this has been done you can press the RUN button to save the changes, and exit the setup screen. Your display will now read Celsius,
Apr 18, 2013 | Honeywell Programmable Thermostat Heater
Temp dispayed in celsius.
Inside the thermostat (behind) are 3 tiny DIP switches.Switch #3 should be set to OFF or click it to the left to display *F.You can use a tiny scerwdriver
Nov 07, 2011 | Honeywell Electronic Programmable...
How do I change my Honeywell FocusPRO6000 TH6110D1005 thermostat to from Fahrenheit to Celsius?
Press and hold the up arrow and fan buttons until the display changes. Then press Next until you see 14 in the display. Change this value to 1 (with the up and down arrows) to get Celsius. (O is Fahrenheit.) Press Done to exit and save the setting.
The manual is available here: http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1005 . Scroll to the bottom and choose a manual then press Download. This particular section is in the Installer's Guide.
I hope this helps.
Jan 30, 2011 | Honeywell Programmable Thermostat Heater
Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Switching thermostat from farenheit to celsius
My thermostat was set on celsius and couldn't get it to change back to fahrenheit. My son suggested pressing both up and down arrow buttons at the same time and it worked. It changed back to fahrenheit.
Feb 16, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,208 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
