Question about Brother XL-5130 Mechanical Sewing Machine
I have the Brother XL-3150. My needle bent, so I took it out. It was a little tough to get out, but I did get it. Now, I can't get a new needle to stay in the holder. Not even the one that bent. Can this be fixed?
SOURCE: brother ult disney machine
Marty, it happened to me! I figured it out, if you need help, feel free to email me, it is the bobbin carriage was not put it--not the bobbin spool, but the whole carriage. feel free to email me and I can walk you through it! I just saved myself a trip to the repair! :)
pyles_brandi@yahoo.com
Posted on Jan 03, 2008
jmeredith
  • 417 Answers
SOURCE: Bobbin holder turns and keeps bending needles
hi,
the whole upper assembly may have come out of alignment when the machine bent the needle, the upper cover may have to come off, and study the inner metal area where the needle is attached for alignment bolts or screws, maybe one has come loose. On ours if you choose the zig zag and adjust it all the way out it will do that everytime. maybe download the user manual at www.brother.com and see if theres something in there also.
J
Posted on Jul 23, 2008
Mimito7
  • 128 Answers
SOURCE: The needle on my Singer 132Q featherweight breaks
Sounds like it is out of time. I recommend you take it to your local repair center.
Posted on May 12, 2009
SOURCE: brother sewing machine model XL-6562.needle holder came off rod.n
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part).
Posted on Aug 20, 2009
bargainbox
  • 1388 Answers
SOURCE: Brother xl 2230 - cannot fill spool as holder does
Check the bobbin winder rubber......remove the top cover and take a look. Remove worn rubber and use as a sample when you go to the Brother Store....also have your model number handy. If you cannot access easily, phone Brother store and ask for a quote to replace.....if it is any more serious they should confirm with you prior to doing additional work.
Posted on Sep 06, 2009
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
Brother XL 260I hook timing. My needle doesn't catch the bottom thread. How do I adjust the timing to fix this?
Make sure you are using a brand new needle. Old, damaged or bent needles often will not pick up the bobbin thread.
Search the internet for "sewing machine timing"
There are multiple web sites and videos that discuss fixing timing issues.
Oct 01, 2016 | Brother Sewing Machines
Brother xl 2600 needle hitting feed dogs
Could be several reasons! Check that your needle is not bent, Make sure that you are using the needle is the needle size required BT specific machine. Make sure timing is checked by ttechnician.
Jul 05, 2014 | Brother XL-2600I
Brother XL 3027 sewing machine the needle hit the hook in the incorrect spot causing needle to bend and will not sew.
That's ok, needles get bent all the time and sometimes broken too. Just give it a new needle (look on the shaft at the top of the needle, you should see a screw to loosen for removing the needle). Note that the needle is made with a flat side on the shank to locate it properly, watch how the bent one is positioned when you remove it.
lp
Dec 27, 2010 | Brother Sewing Machines
The needle on my brother XL 5340 sewing machine does not appear to go down far enough to catch the lower thread.
Hi. Check to make sure that the flat side of the needle shank is facing to the rear (away from you), that the needle isn't bent, and that it is inserted as far up as it will go.
Hope this helps,
Robbie
Aug 16, 2010 | Brother XL-5340 Mechanical Sewing Machine
The little thing that the needle goes into broke. How can i get a new one and what is it called? I have a Brothers machine XL 5130
it's called a needle clamp-check sewingpartsonline.com
on the left hand side click on brother parts
go down till you find your model number there is a brother xl 5130
it's close to the bottom of the page
please rate this with the thumbs in upper right hand corner
Aug 09, 2010 | Brother XL-5130 Mechanical Sewing Machine
HI, my brother xl-2600i is hitting the metal on the bottom not going through to the bobbin. don't know what to adjust. help! thanks in advance.
First, check to ensure your needle is not bent. If its not bent then just adjust your metal plate at the bottom. Loosen the screws and shift the plate back, tighten the back screw first and see if the needle now passes the plate. If not make some more adjustments. Once the needle passes the plate properly, tighten the front screw. Hope that helps.
Apr 13, 2010 | Brother XL-2600I
My xl-5700 the needle keeps breaking or the thread keeps getting all bunched up plus I lost my instruction manual can I gat a new one
About the needle problem, Brother's FAQ gives the following response:
Make sure the needle is correctly inserted with the flat side facing the back and pushed up into the machine as far as possible.
The needle could have been damaged or bent. If so replace with a new one.
Make sure the fabric is not pulled excessively when sewing. Let the feed dogs move the fabric. Do not pull the fabric.
The combination of needle size, thread size and fabric is incorrect.
Be sure to use the correct needle and thread size for the fabric you are sewing.(example: Denim-size 16 needle and 40-50 heavy duty thread).
As for the manual, here's the link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000063/ps21xl55565700ug02en.pdf
Dec 05, 2008 | Brother XL-5700 Mechanical Sewing Machine
Brother XL-5340 sewing machine
Try a new needle, making sure it is put in properly. A bent needle can break thread. Make sure top tension is set properly.
Dec 01, 2007 | Brother XL-5340 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
260 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
