Need a replacemaent control board that is cracked...not operating fan portion board #/E255554 ZL-01
2 Suggested Answers
SOURCE: I need a bobbin
check with these sites about the part
sewvacdoctor.com
a1sewingmachines.come
email them about the part you need
Posted on Aug 28, 2012
How do I my whirlpool model G115NDXZB0
You may have a compressor failure, due to the failure of the fan.
Have you tried turning the fridge off for a few hours and re-starting it?
If the compressor then starts without any unusual noises, it might just be overheated, and a replacemaent fan will cure it.
Otherwise, it looks like a new compressor and fan will be needed.
May 22, 2016 | Whirlpool Refrigerators
My furnace wont turn off
Well Linda, is it the heat portion will not shut off or just the fan in the furnace that continues to run?? If the heat won't shut off, it will get uncomfortably HOT in your house, if its just the fan.....well, its just the fan.
More than likely its just the fan and it is running continually due to a stuck set of contacts in the control board or in the fan control board, if so equipped. If it is a furnace that is older than 15 to 20 years, it could be a mechanical relay that controls the fan directly off another control in the furnace vestibule that senses heat in the heat exchanger. If its an electric furnace, the first stage heat sequencer could be stuck closed causing continual fan operation and possibly one heat element is also energized. There are also several additional issues that could be the cause.
At any rate, its time to contact a reputable service entity to correct your problem. Good luck, Linda.
Dec 04, 2015 | Heating & Cooling
Dryer will not turn on. Lights blink and the Code "F-01" shows in the display
depending on your model The F-01 error code indicates a primary control board failure . If the error cleared after unplugging it for a while, then the control board could have received a power surge or glitch through the electrical lines. Completely disconnecting the electrical power and then reconnecting it will sometimes reset the board and it will operate properly. If your dryer continues to operate properly, then resetting the control board may have fixed your problem.
If the dryer motor continues to stop, then you may have a bad control board. A wiring problem or drive motor failure could also prevent the dryer from continuing to run properly. A technician is normally needed to diagnose and repair this type of problem.
If the F-01 returns and will not clear, then you will need to replace the control board in the dryer
Nov 25, 2015 | Dryers
Where do i find a manual for ZL-031D headphones
Zealot; Model:Zealot ZL-031; Type:Headphones (Headband) ; General Use:ComputerMobile PhoneMedia Player/Tablet; Function:With MicrophoneHi-FiGamingFM RadioVolume Control; Communication:Wireless 5GHz / 5.8GHz; Connectors:3.5mm; Memory Capacity:TF Card Support; Material:Polycarbonate; Color:WhiteBlackRedSilverPurpleBlue; Dimensions (cm) :7cm; Weight (kg) :0.4kg; Speaker Diameter:40mm; Speaker Sensitivity:-80dBm@.01%BER; Speaker Impendance:32; Speaker Frequency Response:2.4GHz; Plug Type:headband; Cable Length:1.5m; Max. Input Power:500mAh; Driver Type:Electret; Sound Channel:2.0; Input Voltage (V) :5V; Modulation Mode:Bottom Control; Transmitting Power:300mah-500mah; Power Supply:computer USB port DC5V; Working Voltage:3.5-4.1V; Battery:rechargeable lithium-ion polymer battery (3.7v 890mah)) ; Standby Time:300 hours; Talk Time:7 hours; Charge Time:7 hours
Nov 25, 2014 | Audio Players & Recorders
The fan inside the furnace cycles on and off several times before finally turning on completely.
You may have a variable speed blower that is not wired correctly to the thermostat or the problem could be the ciruit board.
Nov 10, 2017 | Ruud Rheem Control Circuit Board...
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
Gsl25jfpa bs fridge is warm on top and frozen on bottom and freezer is warm
It sounds like the fan in the freezer is not working , to circulate air , and the coldness is just dropping . This will cause the icemaker to stop working first , then the top portion of the refrig next . As this coldness drops , the lower portion of the fridge ( crispers ) , will freeze . The main control board , causes the fan , not to run . Part Number WR55X10656 . The main control board , is located , behind the refrig , behind an 8 " X 10 " , small panel . There is usually a burnt resistor on the board , which is connected to the fan . Unfortunantly , the whole board will need to be replaced . It is easily replaceable . Doesn't take any special knowledge . All the plugs 6 or 7 , each fit the pin plug designed for it .
Oct 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Jun 20, 2009 | Hunter Ceiling Fan Remote Receiver...
Remote control ceiling fan
Possibly a bad circuit board in the ceiling fans remote function. I would suspect that the circuit board has a thermal issue where once warm it works fine. The most common fault that I have seen is a bad solder connection on the board. Pull the board from the fan and check all solder connections for cracks or dull solder. If you see any of these then reflow the solder connections. If this does not work you probably will need to order a new board from the manu.
Jan 26, 2008 | Dryers
Oven not switching on
the f-01 means the oven control is bad. when your pot spilled it shorted out the control board
Nov 27, 2007 | Ovens
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
