Question about Tag Heuer cj1110.ba0576 Wristwatch
How do i reset my tag hauer? I can't seem to pull out the crown.
    Sniper:
  • 63 Answers
It may have a screw down crown. Try turning the crown counterclockwise see if it unscrews. There is no other reason for it not to pull out unless someone has opened the back and removed the crown and stem then inserted it crooked and it is stuck.
If someone has done this the watch could be damaged.
Posted on Nov 07, 2010
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Instruction manual
    Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps .
    Sep 01, 2013 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
    The chronograph hand of my TAG Formula1 starts at 2 seconds to 12 not at 12 o clock also after reset it stops at this point. What could be the problem?
    If you pull out the crown to the first stop, then press the start/stop button that should move the second had on one second per press. The reset button moves one of the other dials. If you pull the crown out to the second stop, the start/stop moves the minute hand on, and the reset button moves the other small dial round.
    Feb 19, 2010 | Tag Heuer Formula One
    My Tag Heuer chronograph will not reset to zero.
    Try the following, which I discovered by accident on my Tag Professional. Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works for you. Geoff
    Feb 11, 2010 | Tag Heuer Aquagraph CN211A wristwatch
    I need some additional links for my tag hauer 200m water resistant watch
    Your best bet it to contact with Tag Hauer they will send it to you or try from the seller , then take it to any expert watchmaker and get it install
    hope this help
    from
    AmFix Jewelry & Watch Repair
    203 N. LaSalle Street
    Chicago, IL 60601
    Ph: 312 641 7000
    Email: info@goamfix.com
    Web: www.goamfix.com
    Sep 25, 2009 | Tag Heuer Link Automatic Chronometer...
    Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
    Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
    Jan 23, 2009 | Tag Heuer Link Automatic Chronometer...
    Had a new battery fitted to my tag 6000 and now 2 of the dials dont reset to zero
    To reset the chronograph dials back to zero do the following:
    1) Pull the crown out to the position where the date can be adjusted and push the buttons.
    2) Pull the crown out to the position where the time can be adjusted and push the buttons.
    Jan 06, 2009 | Tag Heuer 6000 WH1312.BA0677 Wrist Watch
    Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
    Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)].  Tap Button B (bottom) to reset by step back to zero.
    Incidentally, Button A works Hours register in same manner for position 2.  You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3.  Cheers!
    Jul 25, 2008 | Tag Heuer Link Automatic Chronometer...
    Tag Timer Resets to Wrong Time
    Unscrew the crown and press the lower button, this should advance the minute counting hand one press ata time. Pull ot the crown a further stop to advance the seconds hand and again to advance the tenths counter.
    Nov 04, 2007 | Tag Heuer Watches
    Tag Heuer cj1110.ba0576 Wristwatch Logo
    764 people viewed this question
    Top Tag Heuer Watches Experts
    Jimmy Accardi
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
