Question about Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650SS Gas oven takes a long time to heat up, and then, in the middle of baking, the digital control panel goes blank and the oven goes off. Eventually, the panel will begin flashing and, with luck, we can light the oven and get on with the baking. What is wrong and what kind of a fix is it?
    President:
  • 635 Answers
This is Amana's fault and is common on several oven models and types.
Your timer and clock control board has some loose solder joints and they can be re-attached by any competent electrical repair shop with soldering skills. TV shops can often be convinced to do this for you for a nominal fee.
Posted on Nov 07, 2010
Oven not heating to desired temperature
You will have to place a amp meter over one ignitor wire and turn the oven on to bake.
If the amp draw is 3.3 amps or less,replace the ignitor.
Jul 11, 2010 | Amana ARGS7650SS Gas Kitchen Range
Describe your amana arg7800ww Gas Kitchen Range
can't get the oven to go on to bake. can you help me solve this problem thank you.
Mar 11, 2010 | Amana ARGS7650SS Gas Kitchen Range
This is a gas oven (self cleaning) and the oven part will not heat up. is there a pilot on the oven part of the oven as well as the top part. the top part of the oven will light but the oven won't heat up
There is a electronic igniter.There is on for the bake mode and one for broil.Just do a google search of apliance parts and you will find several places to view the part and some will have parts diagram. Most of the igniters are ceramic and only takes a hair line crack for them to quit working.
Feb 02, 2010 | Amana ARGS7650SS Gas Kitchen Range
WHEN THE OVEN REACHES A CERTAIN TEMPERATURE, EVERYTHING SHUTS OFF. THE DIGITAL DISPLAY GOES BLANK. THE ENTIRE OVEN SHUTS OFF. WILL WORK AGAIN WHEN IT COOLS DOWN.
I had this same problem...I needed to replace the digital pad, cost about $200 online and took about an hour to replace. The heat from the oven wears out the electrical components in the pad...good luck!
Sep 29, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana oven does not work
Check the oven glow bar ignitor. Replace it if it does not glow.
Jun 08, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Mar 18, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven does not heat up - occasional gas smell
you have bad ovne ignitors( bake iginitor is no good
Jan 28, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven temperature
Replace the bake igniter in the bottom of the oven. It corrodes over time and as the resistance increases it finally reaches a point where the voltage is two low to open the gas valve. It's a ten minute job and the part cost $45-65.
Jan 22, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650SS problem
try this site - repairclinic dot com. there are some helps about where the screws are to remove the control panel.
Aug 21, 2007 | Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
245 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
