Question about Zojirushi NP-HBC18 Rice Cooker
No power. only the clock works. Is it possible that a fuse was blown? Is there a service center in new jersey? thanks.
    Genius:
  • 1,672 Answers
Yep!
You are right about it, the THERMAL FUSE just blown up!
Any electronic tecnician can FiX that!
make sure he replace it with same temperature code!
Posted on Nov 07, 2010
No lights,no clock no functions. Power to the unit is good. Any suggestions?
The likely cause for your radio not functioning is a blown fuse on the power supply circuit board. Unless you are able to take the clock apart and solder a new fuse to the board, your best option is to purchase another radio. If this clock radio is a wall plug-in, the fuse may have been blown during a thunder storm.
Mar 24, 2015 | Audio Players & Recorders
My inverter comes on but it does not put out power
Check , if its fuse is okay and also output cable .If fuse not blown , please contact its service center as there is high possibility of chip plate failure.
Sep 19, 2014 | Cobra 2500w Power Inverter
I have a rover cd32 radio /cd it was working fine i stopped for 5 minutes and when i started the car again the radio was dead.the fuse appears ok as the clock is working and are on the same fuse,pushed...
  • This shows a faulty head unit sometimes...
  • The fuses for these systems are usually two.
  • One right behind the music system, clock and the head works on it.
  • Then the second on the fuse box of the car.
  • Usually used fuse is the accessory- cigarette lighter kit fuse. Check for any blown fuse in the fuse box.
  • Then check the connection lines of the main supply(red\yellow), ground(black).
  • If this is not a remedy then go to the service center to get an advice. Do not open the head unit yourself !!
Sep 23, 2011 | Blaupunkt Car Audio & Video
Installed DVD player stopped working possible fuse
It is possible that you have a blown fuse. In this vehicle there are 3 possible fuses that you can check. Under the hood on the drivers side you will find the fuse and relay center. Remove the plastic top by depressing the tabs, You will see under the cover a list of fuses and locations. Look for the IOD or Instrument on Demand fuse, it should be a yellow 10amp fuse. You can remove it and visually look to see if it's bad. The next fuse will be the RDO or Radio fuse, again remove it and inspect the small wire inside to see if it's blown. The last fuse will be the IGN-Batt fuse. This fuse can be moved from on side or the other so note it's location, either to the left or right before removing. This fuse lets you choose to have power on in the vehicle from the battery even without the key on in the BATT position. Again you can remove it and inspect the fuse.
If you find any fuse blown, (the little wire broken inside) you should only replace it with a fuse of the same size. These fuses are mini fuses and can be purchased at any auto parts store or local service garage. If you don't find any of these fuses blown you may want to check the DVD player out in another vehicle to insure that it doesn't have a problem. It too has a fuse which may either be located inside the DVD player or if it's a direct install player it will have an inline fuse. Thanks D.R. Wilkins
Nov 05, 2010 | 2006 Chrysler Town & Country
The clock on my Corolla is not working , it went out , how do I find out if the fuse is blown out or does this have a light bulb and if so where is it located to change it.
The fuse that powers your cigarette lighter port also powers the clock. If only the clock is dead then it is not a fuse issue. This is a very common problem with the 96-05 Corolla clocks. The clocks are very prone to internal failure. I offer a reasonable repair service with a lifetime guarantee, check it out:
www.autoclockrepair.com
There is a bunch of useful info there. Drop me an email if you have questions, thanks!
Oct 10, 2010 | 2003 Toyota Corolla
The center clock-oven module no longer lights up and the oven doesn't work, but the burners on top work. model rf341bxk. The oven light still works. Is there a fuse blown that I can replace?
Hello, welcome to fixya.
Unfortunately many modern ranges do not incorporate fuses into the control panels, other than the 15amp outlets used for plugging in external devices, they are typically the resettable type fuse.
Many manufactures have gone away from the typically glass fuse style circuit interrupters of previous ranges of say 15-20yrs ago and older.
If the clock display is not illuminated nor functioning, but the surface element functions appear fine, it is likely a fault within the clock ( also referred to as a timer or erc ) itself. Check for possible burnt or loose wires going into the timer such as L1 or L2 etc.
**Please unplug the range or turn off the 40amp breaker at your homes service panel before attempting any service to the range**
The part for the timer/clock is # 3196967 and retails for between $167 to $233 at "searspartsdirect.com" and "repairclinic.com" respectively as I type this on June 6/2010.
Hope this info was helpful to you...even if it isn't great news. Please take a moment and rate the info I provided and thanks for visiting "fixya".
macmarkus :)
Jun 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My PLTV-3250 will not power on, all of a sudden. Is there a local tv service location in the Clifton, New Jersey, 07011 area where I can have the TV looked at, since there doesn't seem to be a direct...
Check ur power source, might be ur power source?If it not ur power,than ur power ic inverter is dead.U need a new one.Look in the web. for there Service number,they'll direct u to a Service center or rpair shop they contract with.
Aug 19, 2009 | Protron PLTV-32 Television
100A battery fuse blown?
They more than likely shorted out your 100a link fuse by grounding out your alt cable while replacing it. Sounds like they didn't disconnect the battery before hand. Your car has an idle program which it re-learns every time you lose power, or in your case, turn off the switch. You need to replace this fuse or your car will not charge.
Jul 21, 2009 | 1999 Mitsubishi Montero Sport
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
Zojirushi NP-HBC18 Rice Cooker Logo
902 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
