Question about Whirlpool Dishwashers
We have a whirlpool dishwasher about 3 yrs old that does not clean very good any more. I understand there is a filter that can get plugged with paper (from labels) or residue. Is there an easy fix?
  • 1,998 Answers
Yes with all dishwashers you should use a product called affresh not only does it clean out all build up of soap scum but it also takes away any bad odors in dishwashers and makes the unit run better as well u can find this product at your local home depot they also make this product for front load washers i hope this opinion has helped and if you have any further questions please message me back please remember also to rank how this opinion has helped in your appliance situation
Thanks again
Rick
Posted on Nov 07, 2010
My dishwasher is about 4 yrs old and doesn't clean the dishes. I have tried the usual remedies and nothing seems to work. The glasses especially not only come out streaked, they retain chocolate or lip...
Welcome to FixYa.
Based on your description you`re experiencing the same thing 99% of folks with this type of dishwasher do...eventually.
The good news is it is likely just a clogged up or dirty sump assembly.
Here`s what you can do, I find removing the top rack to be the best place to start.
However I also find sometimes visual "how to" instructions are better than explanations, therefor I`ve attached a video for you to check out.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
This should help you get to the pump filter, spray arm and check for food deposit, broken glass, undissolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, This will be applicable to most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air.
When you`re finished run it through a test cycle and see how it goes. You may even want to run it empty with just a bowl of "white vinegar" on the top rack for a dishwasher bath.
Let me know how you make out and what you find.
Good luck.
Regards,
Macmarkus :)
Sep 20, 2010 | Whirlpool Dishwashers
Miele Advanta G2170 working fine 2 yrs, suddenly starts popping breakers and won't run (on any outlet) Electrical system in home is about 3 yrs old only.
Hi dear.If the washer is tripping circuit breaker,as long as you plug in,there is a Interference filter capacitor inside of the machine.Main power gets connect there first.It should be faulty & needs to be replaced.I hope that helps Thanks.
Aug 31, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
We have a 17.5" Kenmore built in dishwasher. For the past 3 wks. It just doesn't clean the dishes. It's only 3 yrs. Old.
Check the in coming water flow to the machine.
If the striner is clogged clean it.
Refer user manual.
May 21, 2010 | Dishwashers
My Bosch dishwasher is only 2 yrs old and for the following two nights does not want to pump out the water. If I drain it, it sometimes starts the cycle and sometimes not?
If no warning lights show up, then it is a matter of finding if the outlet is blocked somewhere. I am assuming the fact you can drain it manually means the pump is ok. Perhaps some sensor which is covered in muck.
I would start by cleaning the filters at the base and then running the unit with a dishwasher cleaning kit (without dishes in it). Finish cleaning kit is quite good and the instructions are on the pack.
By the way these units normally have a 2 to 3 year warranty on some parts. I am assuming you have the proof of purchase so that you can call the Bosch support guys.
May 07, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Purchasing this Whirlpool dishwasher
probably a new one. lifespan is 10 years average
Apr 05, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Washer won't fully drain.
If this washer has a self cleaning filter(cone shaped) it's probably plugged. Also could be the pump or the belt. Good luck..
Mar 17, 2010 | Whirlpool Washing Machines
My whirlpool dishwasher clean light blinks on and off,and I can no longer run dishwasher.Unit is only 3 to 4 years old
Hi- One of two things- fault in touchpad/control, or bad motor. If you pull bottom kick panel, with a bright light look underneath for water deposits on botom of aluminum motor case. Any motor seal leak will show up here. If you see any crud on bottom, motor must be replaced. Not uncommon to fail 3-4 yrs.Anyway- motor is about 100$ - control 150-175$ Labor varies.- Hope this helps- ED
Mar 01, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
85 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
