Question about LG Televison & Video
Mi portable dvd/cd player mod.dp270b dice no disc y el haz de laser se ve muy debil
SOURCE: portable dvd player - wont play
Hi
Bought a dvd laser lens cleaner for 10 euro played it through the dvd player a couple of times and its working great now
thanks.
Posted on Apr 10, 2008
SOURCE: no lee cd de DVD
Limpia el lente del laser.
Posted on May 28, 2008
ginko
  • 19396 Answers
SOURCE: PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Posted on Feb 10, 2009
SOURCE: DVD PLAYER
my portable dvd player shows no disc everytime i put dvd in player
Posted on Feb 25, 2009
petraman7
  • 1175 Answers
SOURCE: my portable dvd player shows no disc when i put my dvd in player
Hi....
Very lightly clean the laser lens ( looks like a very small eyepiece)
with 91% or better alcohol on a swab. Then very lightly dry it off.
Also..have you tried another DVD or CD in it?
Check for dust or debris in where the laser pickup is
Hola, mi quemador dvd modelo GH22NP21 no me quema los dvd porque? los cd si los quema, pero los dvd no. tengo windows xp sp2 con 248 ram, lee el dvd y guada la imagen en disco duro al momento de insertar...
Los quemadores de DVD cuentan con dos unidades de laser. Un laser es para quemar y leer discos DVD. El otro es para leer discos CD. Es muy común que el uno o el otro falla. Si el aparato todavía está bajo la garantía, puede Ud. pedirles quemador nuevo. Si no, tal vez haya llegado la hora de comprar un nuevo. Lo bueno es ya no cuestan mucho... meno de $30 por quemador de buena marca.
Mar 14, 2011 | LG GH22NP21 DVD-Writer - Internal...
El mouse de mi laptop no funciona ke hago
Dependiendo de tu sistema operativo:
1-Ve a Control Panel
2-Localiza "Muose" o hardware
3-Haz click en el y luego ve a hardware.
4-Si no esta
6-ve a MY Computer y haz un Right Click
7-selecciona Manage
8-luego Device manager y ve si en algun lugar ves un simbolo amarillo;si esta en amarillo haz right click en el y selecciona Update driver.
Si nada de esto funciona ve otra vez al 8 y haz right click y seleciona unistall.Apaga el PC y prendelo otra vez.Se supone que el sistema(OS) lo localize y lo instale automaticamente.
Si no fuciona esto entonces ve a Control PAnel i desintala el driver en ADD or Remove Programs.Usa el CD del mouse e instalalo otra vez.
Escribe luego a ver que pasa,Miguel.
Dec 01, 2010 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
La webcam de mi acer apire one aoa150 se ve
Puede ser causado por varios motivos, te recomiendo verificar:
1. Quitaron el plastico protector de la camara? Esta tiene un plastico que debe ser removido.
2. Está correctamente instalada la camara? Por lo comun ya viene instalado los drivers. en caso de no ser así, en el CD que trae el equipo debe estar el programa para la instalacion de la camara.
3. Está ajustado el brillo de la imagen? En las utilerias de la camara debe estar la configuracion para hacer mas clara la imagen. En caso de no tener en el manual las instrucciones, puedes ajustar el brillo en el software que usa la camara, por ejemplo; en MSN puedes entrar a HERRAMIENTAS- WEBCAM - AJUSTES (o configuracion) y ahi tiene el control de brillo.
En caso de que nada te funcione te recomiendo contactar la tienda para obtener informacion de garantia.
Oct 09, 2009 | Acer Computers & Internet
COMO BAJO EL PROGRAMA DEL DRIVE DE VIDEO Y SONIDO A MI PC
Si tu instalación de Windows es reciente, es muy común que tu sistema de audio no haya sido detectado y habilitado inicialmente. Pero, si usas Actualizar Windows, la segunda o tercera ocasión verás que Windows detectó la falta del controlador de audio en el sistema,
y lo instalará automáticamente.
Si este no es el caso, entonces necesitas usar el CD que vino con el tablero, y si buscas en su contenido encontrarás un directorio llamado "Drivers" o algo parecido, o bajo el nombre del fabricante del aparato de audio.
Si logras encontrarlo, entonces ve al Panel de Control y corre el Device Manager (no sé cómo lo llama en español), que es el que despliega la información acerca de los componentes internos y externos de tu PC.
Muy probablemente encontrarás al menos uno o dos que tendrán un ícono amarillo, o rojo, indicando que el aparato en cuestión no está configurado y por supuesto, no funciona.
Si este es el caso con tu tarjeta de audio, entonces haz un click con el botón derecho del ratón sobre el aparato y selecciona "Desinstalar" (o como se diga en español). Cierra todos los programas y recicla tu PC normalmente, usando "Inicio->Reiniciar el sistema".
Cuando Windows arranca otra vez, espera unos minutos. Verás mensajes de que Windows ha detectado nuevos componentes, y que está instalando sus controladores. Un par de minutos después, todo estará de vuelta a la normalidad.
Si en vez de esto el mensaje dice que no se pudo instalar, o no se encontró, entonces busca, dentro del Panel de Control el ícono para añadir componentes. Aparecerá una ventana donde los nuevos componentes se detectarán automáticamente, pero nuevamente aparecerá el mismo mensaje de que no se encontró el controlador. Pero, te da la opción de buscar en un lugar específico de tu sistema por el controlador.
Aquí entonces busca la letra de tu aparato de CD/DVD, que contiene el disco que vino con el tablero, y seleccionas el directorio anterior. Luego, presiona OK/Continúe tantas veces como sea necesario.
En el último de los casos, dirígete a la página del fabricante de tu tablero, y anda a la página de apoyo al cliente, en la página de Descargas busca el controlador, basado en el modelo del tablero en cuestión.
¡Buena suerte!
Jul 17, 2009 | Asrock 775VM8 Motherboard
Hola, mi problemas es con mi satellite M205, resulta q la unidad de cd-rom no esta, y no puedo abrir el compartimiento para poner los cd's, la luz q aparece ahi, esta apagada, no se q es, gracias
haz visto un pequeño agujero en donde se pone el cd trata de meter algo muy pequeño alli y se abrira o trata de volver a instalarlo
by kevin
Jul 01, 2009 | Mozilla Firefox
Ibm 06p2525 alguien podra decirme como configurarla para que inicie desde el CD de instalaciã³n de XP pues en el bios, no viene opciones de arranque. Y ya probe con F1 hasta la F12 y ninguna me...
El disco de instalación y su programa que usa (¿windows XP home?) son muy diferentes y lo que usted quiere hacer no va a darlo ningún beneficio. Déjalo todo como se fué diseñado. Aunque si podría hacer esto el resulto estaría una computadora muy lenta porque se va a tener partes que mueven. En muy poco tiempo necesitarái un disco duro nuevo y un drive de CD-DVD. Tiene una mente muy inteligente, pero deja estas cosas en vivo. Déjame que te doy una precaución. No juega con la tarjete madre, porque es una cosa muy delicada, sino que no estás preocupado pagar cómo US $ 300- 500 dólares y labor de mano de igual, porque quemastes la targata madre. No tengo más tiempo explicarlo pero mantenga sus dedos fuera de esta cosa tan delicada. Muchas gracias para la consideración y opción de nuestro servicio. Mi nombre es Constantino )arzconst es mi contraseña interna con Fixya.com=
Jun 13, 2009 | Computers & Internet
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
No tengo el cd y quiero intalar una camara logitech 961306
hola raul....
tienes que ir al web de logitech a esta página para elegir tu país.
una vez que has entrado en el web... haz un clic en el enlace para 'Asistencia' (arriba del todo en letra muy pequeñita). en la parte 'Buscar por nombre' elija cameras web... y debajo el modelo, y haz un clic en la flecha.
en la página siguiente, haz un clic en descargas y después en tu sistema operativa y después en el archivo....
Muy Importante:
para elegir el archivo necesitas saber si tu sistem operativa es de 32 o 64 bits... lo puedes averiguar haciendo un clic derecho en el icono de 'Mi Pc' (en XP) o 'Equipo' (en Vista) y seleccionando propiedades del menú emergente.
espero que esto te sirve de ayuda, y avisame si tienes alguna pregunta mas!
bru*
Feb 17, 2009 | Logitech QuickCam Messenger Web Camera
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Televison & Video Logo
106 people viewed this question
Computer Repairing
Computer Repairing
