Question about Freezers
I want to drill a hole in the side of my freezer for beer lines. where should i drill
  • Freezers Master
  • 43,501 Answers
Somewhere near the center of one of the sides is best.... but it can still be a guess and by golly deal....
Just keep the beer handy and if you hit a refrigerant line just down a few to make you feel better... :-)
heatman101
Posted on Nov 07, 2010
Reversing door
some can be many can't use your head and look at the hinges
May 11, 2015 | Freezers
I need to run several 3/8" tubing out from inside
you should not drill any holes in the unit the cooling lines run throught he entire cabinet.why do you need to drill a hole in the unit?
Mar 19, 2011 | Frigidaire Freezers
Why would the top and sides of small chest freezer be warm tot he touch
Some freezers have the refrigeration condenser coils located in the walls of the freezer as opposed to a dedicated coil and fan. This is why you should never drill into a freezer or cooler cabinet to install hinges or make holes for draught equipment.
In order for the door opening to not freeze around the gasket, freezers have a low wattage electrical heater installed and this is probably the heat your feeling on the door.
Hope this answers your question
Nov 21, 2010 | Freezers
I have a 10 year old Whirlpool Commercial 19.6 cu.ft. upright freezer. No. EV200N . It just stopped working. The inside light is on... temp on the normal setting.... Doesn't cool... most of the food had...
Hi Pete,
I will take you up on the beer if we get this going.
If the fan is running and not cooling there is one thing that would be repairable other than that it is not worth it.
Go to the back of the freezer and at the bottom is the compressor (looks like a bowling ball, kinda anyway). Unplug the freezer, on the side of the compressor is a small black cover with wires going into it. Pry off this cover and you will see a couple of parts, these are the overload protector and relay.
Take a picture with your phone or digital camera so you know how they hook up then pull them off, they are tight but will pull straight off. If the relay rattles the part is bad, that simple. If not I will have to buy you a beer as you will most likely need a new freezer
May 09, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
I have a chest freezer that i want to place outside but need to l
fridge/freezers are designed to operate at plus 10c to 35c .a shed will just about do but will not work at its best.have you thought about a " lean to " to store your freezer in.do NOT drill hole in freezer walls.
Feb 21, 2010 | Freezers
I want to use my freezer for beer. Can I raise the temperature by changing the thermostat? Any other suggestions besides using a fridge?
Not sure of your make/model. If its a standalone freezer you could exchange the termostat with a Fridge, or you could jury rig a seperate line voltage thermostat with probe in the compartment, which you would plug the fridge into and would override the internal thermostat (internal thermostat would always be calling for cooling because the line voltage thermostat would be set higher--any time the temp increased above the set point on the line voltage tstat the relay would close and the freezer would run). An anti freeze alarm coupled to a simple relay or contactor would work for this purpose... depending on how handy you are I could explain all the necessary components...
Oct 11, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Punctured gas line/ uses R-12
not very easily. Most freezers have the evaporator and condenser inside the wall of the cabinet and you cannot access them. If the puncture is in the condenser you can put in an exterior condenser however the parts break down for your model does not offer this option (:
Apr 08, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Dec 26, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Loose handle
yes , on most freezers the door inner panel liner needs to be removed , that will sometimes require the removal of the door gasket that may be old to the point where it to needs replacing. then finally you can get to the back side of the door and snug up the screws that hold the handle from the back. usually fine thread screws. be sure to apply loc tite and snug up good , we don't want to do this again any time soon. you can take a chance and try pulling out the handle and cutting the screws and then drill the hole in the handle out to where you see a hole in the side of the handle from the front, then counter sink the hole and use a drill screw or a small toggle bolt to resecure the handle . no real wires or refigeration tubes in the door, so its an option. good luck
Nov 24, 2008 | Freezers
Freezers Logo
137 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
