Question about Vizio VX32LHDTV10A 32 in. LCD HDTV
The LED vizio comes on the front of the tv...........screen is blue with floating signal saying No Signal!.
  • Vizio Master
  • 8,457 Answers
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Posted on Nov 07, 2010
Why does the tv screen say no signal?
The "No SIGNAL" comes on if the TV does not sense a signal on the selected input. Chances are that the TV is looking at a different input port than you are connected to in the rear. Check to be sure that the TV's selected source matches where you connected your device.
Sep 06, 2014 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
Powers up then I get a blue screen that says no signal and it shuts right off in 3 seconds
Power supply regulator fault. Repalce the power supply regulator board.
Apr 02, 2012 | Vizio VW42LF 42 in. LCD HDTV
32in vizio tv problem. blue screen
You can if it has it connect to cable fitting and or the various av jacks on set---use original remote and switch inputs to make sure you are on the one you are hooked up to.
Mar 12, 2012 | Vizio Televison & Video
Sreen blue, no signal floating across screen
Hello
Check all the signal cables at the backside of your Vizio for firmness. If there is any loose or bad cable connection, especialy with HDMI; will poise this problem. Check the input selection also. If improper input selection is done, there will be no signal logo will fly around.If you have selected TV instead of HDMI, when HDMI is connected and you want to see the programme, is an example of improper signal selection. Check these. OK.
May 12, 2011 | Vizio VO32L 32 in. LCD TV
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
Vizio say's no signal tried auto search for channels nothing comes up just a blue screen says no signal
Fully check your antenna system... check your plug connection check you have plugged it in the right socket & there is a signal, try the antenna on another unit.
Feb 05, 2010 | Vizio GV42L 42 in. LCD Television
Vizio TV with "No Signal" floating on screen
Tries take out the HDMI cable and replug it back in the HDMI socket.Unplug the Directv power plug and replug,press the off/on botton on again to reboot the signal.Should be every back to normal.
Sep 29, 2009 | Televison & Video
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Vizio VX32LHDTV10A 32 in. LCD HDTV Logo
499 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
