Question about LG DLE5977 Electric Dryer
Smells like butane when I run my dryer - LG DLE5977 Electric Dryer
Do i need a convertion kit to convert to propane or is it in the line
You will be needing to find the manufacturer of the clothes dryer and call them on the telephone to ask this question. Look on the plate telling the manufacturer and the model and the serial numbers.
You will need this information for your phone call.
I am not certain, but I believe dryers cannot run on propane or butane.
I think the only run on "natural gas" or on LP gas ( liquified petroleum gas.
The two different gasses have different orifices for the pressure and flow of fuel.
God bless your efforts.
Oct 27, 2015 | Dryers
Weller Pyropen WPA2 extinguishes itself after a few minutes.
Gas (condensation really) may be freezing and constricting flow. Try warming the tip a bit with a hair dryer see if it goes longer.
Jan 11, 2014 | Weller WPA2 Pyropen Professional Self...
Dryer smells like smoke
open up the machine lint can get into many parts of the cabinet clean that out Also blow air (duster cans are ok) through the motor vents. this may prevent a FIRE.
Nov 05, 2012 | LG Dryers
Ge duet dryer smells and is rattling
what is your model number is then we can get started then
Sep 09, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
Lp gas dryer. sometimes when drying smells like butane lighter. venting is wright i think i followed manuel for correct length of venting.maytag dryer 8 years old. thank you
If you have recently painted or varnished something in your house the fumes could be the cause. They react to the heat in the dryer. Let the house air out for a few days.
May 07, 2010 | GE DBXR463GB Gas Dryer
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Maytag dyer was squealing now smells like burnt rubber
Sounds like you may have a belt slipping.Take the back off &see what the belt looks like.
Aug 28, 2009 | Whirlpool LER4634J Electric Dryer
I have a soured smell in my dryer when it not running
Does it appear that the smell is in the cabinet rather than the drum? I'm guessing that bugs or mice are living in there. There are no components in the dryer case that would smell except for a slight electrical odor. Remove the case and look around! Look for droppings around the back.
Aug 26, 2009 | Dryers
My dryer smells like smoke
just ry to run in on air dry for a while mayee wth dryersheets. charcoal and baking soda are also good at absorbing smell if you can find a way to implement them maybee baking sod box in dryer not running
Jul 09, 2009 | Frigidaire GLGQ2152ES Gas Dryer
LG DLE5977 Electric Dryer Logo
199 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
