Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer model wed5300sq0
Dryer is not heating, this happened before and the vent hose was kinked, is there a safety button. We made sure the hose is unkinked and no lent. Still will not heat. Help!
  • Anonymous Dec 02, 2008
    dryer was running, model WED5300SQ, and then stopped. Would not restart. Did not trip circuit.
My dryer heats but it takes more then 3 x to get the clothes completely dried. Why does it take triple the time to dry my clothes now.
Posted on Apr 03, 2010
  • 5,911 Answers
If your dryer runs, but does not heat, here's a helpful link you can use that will assist you in determining the cause.
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Sometimes it take more than just unkinking the dryer hose and cleaning the lint trap. If you haven't cleaned the dryer ducting in a while, you may have a clog causing the dryer to overheat. If the dryer overheated, more than likely you have a blown thermal cut-out. The heating element may have also been damaged. Read through the link I provided and let me know if you require further assistance, or have any questions. I hope this helps you.
Posted on Jun 15, 2008
I have the same dryer and recently ran into the same problem. The timer went out first and caused the dryer to run all night long, (easy fix 53.00) once replaced tried dryer again and no heat, when it ran all night it over heated and burned out the coil, i just ordered one online for 47.30. 2 screws and 2 easy connect wires are that hold it in. you can test with a multimeter or take it out and look for seperation between the coils.
hope this helps
Posted on Nov 25, 2008
Whirlpool condensed tumbler dryer
check ur dryer vent in the back u might have pushed it back too far and kinked the hose ar u might have a buildup of lint in the dryer vent pull the dryer out and take the dryer vent off and run a load of clothes like this if it works look for a lint buildup in the hose or u just had the hose kinked
Feb 26, 2010 | Whirlpool LER5636P Electric Dryer
Runs but doesn't heat
check dryer hose u might have pushed dryer back too far and kinked hose or have a buildup of lint in the dryer vent if not check for continuity thru ur overheat safeties theres usually 2 or 3 of them on the element housing an they r round UNPLUG UNIT AND TAKE THE 2 WIRES OFF 1 switch at a time and chech and make sure u have continuity thru all of them but its probably gonna be in ur dryer vent unhook it from thee back first and try to dry a load if so u have a kink or too much lint in vent
Feb 24, 2010 | Roper REX4634KQ Electric Dryer
My dryer takes almost 2 hours to dry a normal load of clothes.
You have a clogged vent , or kinked vent hose , or the hose to the outside ( possibly in the wall ) , is clogged with lint . A dryer , either heats , or doesn't heat . The venting , is what causes the excess timing , for the clothes to dry .
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer model number WED5300SQ0 wont start
take a meter and check door switch then if good take the back off and check all thermostats,thermal fuse,AND if your belt is off theres a safety switch on the idler pully.hope this helps
Nov 15, 2009 | Whirlpool WED5300S Electric Dryer
Whirlpool dryer model LER4634J...will heat fine for 3 or 4 loads in a row, then may not heat for a couple cycles. then work fine again. when i run it i use the heavy/60 min. cycle. when it drys it works...
possible timer, or electrical issue in wall receptacle.be sure wall venting is perfectly clear w/no hinderance to air movement whatsoever .try removing vent hose off dryer for a couple of loads,to bypass venting completely just for testing. otherwise the safety thermostats or cycling t-stats may be in question
Nov 12, 2009 | Whirlpool LER4634J Electric Dryer
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer wont start
Make sure the air flow from dryer is good thru the vent hose to outside . Make sure the vent hose itself is not kinked . pt # 3392519 is the thermal fuse .
Aug 26, 2009 | Whirlpool LER4634J Electric Dryer
I HAVE A WHIRLPOOL DRYER,MODEL NO. LER5636EZ2. THERE IS NO HEAT. THE DRYER WORKS FINE OTHERWISE. I HAD THE MAIN HEATING ELIMENT TESTED. IT SHOWED TO BE OK. ANY SOLUTIONS? THANK YOU.DOUG.
Hi Doug, Check your vent hose and both ends of it as well (dryer outlet and wall vent). Take the hose outside and clean it out. Reinstall it with as few kinks and bends as possible. If there is debris under or in the lint trap cavity, remove it as well as possible, This should be what you need.
Regards, --W/D--
Please feel free to rate this solution!
Jul 28, 2009 | Whirlpool Dryers
Whirlpool dryer not drying all the way
you need to clean the vent in house wall.Make sure vent hose in not kinked.
May 08, 2009 | Dryers
Whirlpool dryer isn't heating as it should
check your outside vent chances are that you have a kink in your hose or the venting is clogged let me know what you find.....bill
Jan 10, 2009 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
2,450 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
