Question about Dirt Devil BD10050 Bagless Handheld Vacuum
Dirt Devil BD 10050 Scorpion will not hold a charge--runs down in about 60 seconds--unit is only a couple of months old.
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil M084600 Dynamite
If it is only 2 months old, then it is under warranty, take it in for warranty repair. There may be a circuit breaker on it, usually on the back at the bottom, it there is, push it to see if it has tripped.
Posted on Feb 28, 2008
reddevil6
  • 1673 Answers
SOURCE: dirt devil vision bagless vacuum- not working
You didn't say how it runs before going off. You could have a clog in the hose or dirt inlet by the brush roll. There is a thermo protector on one leg of the wire going to the motor, if it is bad, it could be sensing the motor getting hot and casuing a shut down. Could be just a bad connection somewhere and vibrations casuing it to loose contact. Could also be a problem with the motor.
Posted on Apr 15, 2008
Agent Don
  • 310 Answers
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
SOURCE: Dynamite Dirt Devil Hose
I figured out how last night.
Take a screw driver and unscrew the screw on the top of hose and take the hose out and take a pen or something long enough with grip to get all of the junk out.
The circulation still isn't as strong though.
Posted on Dec 12, 2008
  • 7 Answers
SOURCE: dirt devil vaccum #088915 won't pick up.
well the first thing i would look for is if the brushes turn turn it over bump the on off switch if it turns the belt is fine but u might have a clog in the bottom if that the case have to pull cover from thhe bottom take the belt and roller brush off and look up insde where the junk sucks up use a wire hanger if u need and after that clean out where the dirt goes in bag or canister........hope this helps
Posted on Dec 17, 2008
Dirt devil easylite 7.2 v does not hold charge. Can you suggest any fix? Thanks
Sorry to say that the batteries seem to be worn out. Usually this is caused by using it for to short a time each time you use it. Batteries develop a 'memory' after several short time uses, and can only be charged the time it 'Thinks' is a full charge. You can try running it until it almost stops. Then let it sit for about an hour turned off, then turn it on again, and run it till it almost stops. After doing that put it on the charger for 8 hours. Then run it until it almost stops again. then charge it again. That process sometimes breaks the memory problem. If not, you need new batteries- or a new dirt devil.
Jul 02, 2017 | Dirt Devil Vacuums
Hand vac doesn't hold power
Mostly likely it needs a new power pack, but you could try cleaning off the contacts first. Use a pencil eraser and clean the metal power contact on the charging unit and the vacuum. Then charge it over night. If that doesn't help, charge the power pack.
Oct 15, 2014 | Dirt Devil Gator 18V Cordless Hand Vacuum...
Dirt devil instruction manual
Hi! I have included a link to the instruction manual for model M0802RED. Hope this helps! http://dirtdevil.com/file/329/
Sep 05, 2014 | Dirt Devil M0802RED Scorpion Handi Stick,
We have a Dirt Devil Scorpion hand held 6.0 volt DC vacuum model BD10050 manufacturing code B10C. Is it best to leave it plugged in or not? It does not say AccuCharge anywhere on the body or on the...
If it is a NiCad or a NMh you should only charge it when it needs it. A lithium can remain on the charger. Your battery packor the bottom of the machine will have the marking of what kind of battery it is.
Jun 06, 2017 | Royal Dirt Devil BD10050 Scorpion...
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
Dirt Devil BD10050 Bagless Handheld Vacuum Logo
102 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
