Question about Orion STV2763 27" TV
The tv is connected to Dish Network as TV2. I accidentally changed the channel & now I can't get it back to channel 90 - it only goes to 13 now. How do I fix this?
  • Orion Master
  • 1,212 Answers
In the menu screen, you must find antenna connections. For example " TV Air "(over the air channels 2 through 13) or cable TV. You must tell the menu to select cable TV (with the original remote). This will allow you access to channel 90. Thanks for asking and show a few hands of support.
Posted on Nov 07, 2010
When I change the channel on tv2, it also changes the channel on tv1. I have changed the address for tv2's remote, but it still changes tv1's channel.
Hi my nameis Mike Houston of DISH Network and I see your TV2 changes TV1 as well, thereis an easy fix to this problem. You will want to make sure the receiver is inDual Mode and then make sure the TV2 connection on the back of the receiver isin the right port. I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/same-video-2-tvs.I will leave my e-mail if you have any questions Michael.houston@dishnetwork.com.
May 22, 2011 | DISH Network DVR-625 DTV Receiver /...
Can't get my westinghouse tv to recognize dish network
Happy to help get that fixed right away!
You mentioned that your TV is not recognizing the DISH Network signal, since wedo not know how many TV's your receiver is able to support, or whether it's theTV1 or TV2 having the issue I will address them both.
The first thing we want to do is ensure that all connected components arepowered on (VCR, DVD Player, etc.). Check what channel or input your TV iscurrently on by powering the TV off then back on and noting the channel orinput that appears on screen when the TV is powered on.
If TV1:
Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4,if it has "Home Distribution" output (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; most TVs have a "TV/Video", "Input", or"Source" button. If the issue persists, check that theconnections between your DISH receiver and your TV are secure then reset thereceiver by unplugging it from the outlet for 10 seconds then plugging it backin. If not fixed then connect another component (VCR, DVD Player, etc.) to thesame TV, using same cable, same input, and same channel to see if it works. Ifit works with the other component then call us at 1-800-333-DISH (3474) foradditional troubleshooting, if it still doesn't work with the other componentthen the cable should be replaced.
If TV2:
Access "Modulator Setup" from TV1 by pressing the menu button(on the top left of DISH remote) then pressing the numbers 6-1-5. Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture, verify the mode (air or cable) that TV2 is on. Then change themodulator setup to match this mode (air or cable). After changing modulatorsetup, tune TV2 to the channel that appears under "TV2 Out" onscreen. Check that the connections between your DISH receiver and your TV aresecure then reset the receiver by unplugging it from the outlet for 10 secondsthen plugging it back in. If not fixed then connect another component (VCR, DVDPlayer, etc.) to the same TV, using same cable, same input, and same channel tosee if it works. If it works with the other component then call us at1-800-333-DISH (3474) for additional troubleshooting, if it still doesn't workwith the other component then the cable should be replaced.
Phillip Chang
DISH Network Customer Service Representative
Feb 06, 2011 | Westinghouse SK-32H240S Television
I need to get to channel 73 to connect to Satellite Dish network, but it keeps telling me there is no channel in list ???? what do i do..Thanks
If the TV will go to channel 60 go to TV1 hit menu 6-1-5 go to tv2 out select air. This should change tv2 out to read 60 make sure you don't change the TV 1 output. Select done to save your changes and it should be resolved!
Daniel Busa
Feb 01, 2011 | Haier HTF20 20" TV
I have lost the remote controller for our Sansui VCR/DVD player combo, Platinum Plus model. I bought a universal controller and got it to turn the player on and off but I can't get a picture ont he TV. ...
We would be happy to help you get your TV back up and running. Thefirst thing we want to ensure is that all connected equipment is on.Wealso need to know what channel your TV2 is currently on, we will do this byturning the TV off then back on and noting the channel or input that appears onscreen when the TV is powered on, if the TV is not on channel 60 or 73, tune to60 or 73. Then Access "Modulator Setup"from TV1 by pressing"Menu", 6 for "System Setup", 1 for"Installation", then 5 for "Modulator Setup". Tune TV2 tothe channel that appears under "TV2 Out"on screen. If stillno picture and the mode for TV2 is "Cable", change it to"Air" and change the channel on your TV2 to 60, if it is already on"Air" then change it to "Cable" then change TV2 to channel73. If the issue is only on one receiver, unplug the DISH receiver for10 seconds and plug back in. The next thing we want to check is the connectionon the back of your receiver labeled "Home Distribution", this cablecarries the picture all the way to your TV2. Start by removing the connectionand screwing it back in, make sure all the connections going to your TV2 arehand tight. These steps should get your TV2 up and running.
We want to thank you for being a valued DISH Network customer!
Phillip Chang
Jan 21, 2011 | Toshiba SD-V392 DVD Player/VCR
Cannot get it to work with dish network. It won't accept channel input either!
Hello! If your tv just won't cycle to the correct channel you can change the setting if its tv1 you need a channel scan if it's tv2 try these steps:
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
Dec 31, 2010 | Insignia IS-LCDTV32 32 in. Television
I have dish network and am trying to watch tv on my gateway plasma. how do i connect my satelite cable to plasma to get picture?
We would like to guide you through the connection process,but depending on what kind of receiver and TV you have this process may vary.Visit our "How to connect receiver" page here:http://www.dishnetwork.com/SupportSection/setup-receiver.
Once we have everything connected correctly, check what channel or input yourTV is currently on by powering the TV off then back on and noting the channelor input that appears on screen when the TV is powered on.
Steps for getting picture on TV1:
If you are using a Coax Cable to connect the receiver to TV1, check thereceiver's back panel for the output name. If your receiver has a "TVCH 3/4 out" (non-ViP Receiver): Tune TV to channel 3 or channel4, if it has "Home Distribution" output (ViP Receiver):Tune TV to channel 62 or 75. If using non-Coax (RCA,Component, or HDMI) to connect receiver to TV1, cycle through the inputs untilpicture appears (this information may appear on the remote sticker), mostTVs have a "TV/Video", "Input", or "Source" button.
Steps for getting picture on TV2:
Access "Modulator Setup" from TV1 by pressing "menu"then 6-1-5. Tune TV2 to the channel that appears under "TV2 Out" onscreen. If still no picture, change the "TV2 Out" mode fromAir to Cable, or if it's already on Cable, change it to Air. Then change thechannel of TV2 to what is now displayed under "TV2 Out".
If the issue is only on ONE receiver, unplug the DISH receiver for10 seconds and plug back in. It may take up to 5 minutes for the reset processto be completed. If you still are not getting a picture, connect anothercomponent (VCR, DVD Player, etc.) to the same TV, using same cable, same input,and same channel to see if it works. If it works give us a call at1-800-333-DISH (3474) for additional troubleshooting, if you don't get apicture with the other component, replace the cable.
Hope this steps help, and thank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
Dec 02, 2010 | Gateway GTW-P42M303 42 in. Plasma...
No picture! The Dish TV guy programmed the tv on channel 60 but there is no picture. He said its a tuner problem in the tv. Any ideas on what could be wrong? Can the tuner be replaced or is it some other...
Wewould be happy to help get that fixed right away. The first thing we want toensure is that all connected equipment is on. You mentioned that your TV is on channel 60, to confirm this turn off the TV then turn is back on and note the channel or inputthat appears on screen when the TV is powered on, if the TV is not on channel60 or 73, tune to 60 or 73. Then Access "Modulator Setup" from TV1 by pressing"Menu", 6 for "System Setup", 1 for"Installation", then 5 for "Modulator Setup". Tune TV2 tothe channel that appears under "TV2Out" on screen. If still no picture and the mode for TV2 isset to "Cable", change it to "Air" and change the channel on yourTV2 to 60, if it is already set to "Air" then change it to"Cable" and change TV2 to channel 73. If the issue is only on one receiver, unplug the DISH receiverfor 10 seconds and plug back in. The next thing we want to check is theconnection on the back of your receiver labeled "Home Distribution",this cable carries the picture all the way to your TV2. Start by removing theconnection and screwing it back in, make sure all the connections going to yourTV2 are hand tight. These steps should get your TV2 up and running.
Phillip Chang
Dec 02, 2010 | Toshiba 27A43 27" TV
Need to change channel to 73 so my dish tv will work, it seems the highest channel tv set will go is 69
We would be happy to help with that. Some TV's do not havethe ability to go as high as channel 73; this may be the case for your (enterbrand here). We would recommend changing the channel that your DISH Networkreceiver outputs the picture for your TV2. Start by pressing the"Menu" button, from the main menu press 6 for "SystemSetup", then 1 for "Installation", and then 5 for"Modulator Setup". Under TV2 we are going to change the mode to"Air", the channel displayed beside it should change to 60, selectdone on the right side of the screen to save the changes. Now change thechannel of your TV2 to 60 and you should get the DISH Network programming. Wehope this helps. Thanks so much for being a valued DISH Network customer! Phillip Chang DISH Network Customer Service Representative
Nov 30, 2010 | RCA 27F530T 27" TV
My remote control only works for tv on & off and volume but not to change dish channel
I experienced this problem as well. I have a dual receiver and had issues turning channels on TV2; but counld easily access the volume. After reading the Dish manual, I learned that my TV1 and TV2 remotes connect through different signals (IR = infrared for TV1; and UHF= ultra-high frequency for TV2).
Check your remote to see if there is a UHF logo at the very bottom (under the Dish Network logo). The UHF remote sends ultra-high frequency radio signals to a UHF antenna which is connected to the back panel of the receiver. Make sure that you receiver is properly dusted and then check to make certain that the UHF antenna located on the back of the receiver is positioned straight-up. When the antenna is not correctly positioned it can cause problems with your remote signals.
Oct 06, 2010 | DISH Network IR Remote Control
I have dishnetwork tv1 reciever is fine and shows tv2 is working but cannot see nothing but a blue screen on tv2. Dishnetwork will come out for 95.00 but the last 2 times they were here(free of charge),...
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on.Wealso need to know what channel your TV2 is currently on, we will do this byturning the TV off then back on and noting the channel or input that appears onscreen when the TV is powered on, if the TV is not on channel 60 or 73, tune to60 or 73. Then Access "Modulator Setup"from TV1 by pressing"Menu", 6 for "System Setup", 1 for"Installation", then 5 for "Modulator Setup". Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture and the mode for TV2 is "Cable", change it to"Air" and change the channel on your TV2 to 60, if it is already on"Air" then change it to "Cable" then change TV2 to channel73. If the issue is only on ONE receiver, unplug the DISH receiver for10 seconds and plug back in. The next thing we want to check is the connectionon the back of your receiver labeled "Home Distribution", this cablecarries the picture all the way to your TV2. Start by removing the connectionand screwing it back in, make sure all the connections going to your TV2 arehand tight. These steps should get your TV2 up and running.
Phillip Chang
Oct 02, 2010 | JVC AV-27530 27" TV
Orion STV2763 27" TV Logo
424 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
