Question about Rollei 66 Dual Slide Projector
I need to know where in brisbane I can get hold of globes and fuses for a Rollio P35A slide projector
  • 48 Answers
Any store that sells Osram or Philips can supply the bulbs (globes). Fuses are available from any electronics store. They do not have to be silica filled.
Posted on Oct 21, 2011
Seeking replacement lamp
Try Bulbman.com or Bulbs.com or the retail chain called "Batteries PLUS Bulbs".
If they don't stock them, they should be able to point you toward someone who does. Good Luck !! Jim
Jun 06, 2014 | Braun Office Equipment & Supplies
A slide got stuck in the projector, and when I took it out the projector just died. No power. Any ideas about what's happened? Thanks
If this is a Kodak Slide Projector, there are 2 thermal fuses (1 is in the motor and NOT replaceable and 1 is in the area of the lamp). Almost ALL Kodak projectors had 2 thermal fuses as described. You need to determine the model, as that will determine which fuse or motor assembly you will have to buy & install to fix your projector. If its a Kodak, let me know the model and I can help you further! You can buy parts for Kodak projectors at: www.micro-tools.com.
Good Luck! Jim
Feb 04, 2013 | Office Equipment & Supplies
I have a H27A optoma projector, glass inside has broken, globe is not broken projector does not work and fan and globe do not come on
Might as well unplug it from the mains and carefully remove the cover and look inside to see where all the damaged optical bits are. Then you can figure if it's worth fixing it. Sounds like a fuse or overtemperature switch may be stopping the unit from operating anyway.
Apr 10, 2011 | Office Equipment & Supplies
I have a acer projector ph110, it telling me to replace the globe. Change the globe but can't get into the menu screen to reset globe hours. Try pressing the menu botton but it stll have the warning...
Hi, I had the same problem all you have to do is connect something to the projector like a laptop or dvd player so it has a signal. Once the picture comes up of what you are projecting from the laptop or dvd player you can enter the menu and reset the lamp hours. Hope this works for you if not please let me know.
Mar 30, 2011 | Acer PH110 Multimedia Projector
PLV-Z5 Projector, The change lamp light was flashing and closing the machine down straight after opening the slide, I changed the globe and it still does the same, I can not set/reset globe replacement...
It will continue to do this until you reset the counter. I'm not familiar with Sanyo projectors, so I'm not sure of the steps to do this. Some projectors have a sequence of buttons you push to reset it, others stay on long enought for you to go through the menu and reset it. Sometimes the new lamp comes with those instructions. If you don't still have those papers, or the owner's manual, you can go on-line to contact the manufacturer and they can tell you how to do it.
Jan 13, 2011 | Sanyo PLV-Z5 LCD Projector
Kodak Ektagraphic model B-2 slide projector.- It does not start. I checked the power cable and motor OK but I don't know how to reach and check the thermal fuses. I also don't know how to reach the...
If the motor is "OK" (turning), then it's not a fuse, it's the belt that the motor drives to power the slide change mechanism. There are 2 belts: 1 that drives the fan & one that drives the slide change mechanism.
Nov 02, 2010 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
When I turn the projector on the red LED lights both stay lit. Have tested globes and also changed same. Still red LEDs stay lit. Have checked fuses. All OK
Based on your description, what usually causes the condition you are seeing is a loose terminal in one or more of the lamp sockets or the mating terminal assemblies (the one on the lamp module & the one in the projector itself). In one of these contacts you have a bad connection.
Oct 11, 2010 | Kodak Ektapro 9020 Slide Projector
Infocus LP-820 no power
You should get some indication of power even without the globe. This can however be a problem relating to the globe not being inside the projector.
Most projectors use a switch inside so they know when a lamp is installed. Some have several of these and a fuse that is on the lamp unit itself.
Replace the lamp back into the projector and apply power again. If you get lights then you have that much solved at least.
If there are still no power lights at all, then you may have had a power surge that not only killed the globe, but has blown the internal fuse for the power supply as well (or even killed the power supply)
To get access to the power supply you will need to disassemble the whole unit almost. If your not comfortable doing this, then I would advise getting it checked over by your local tech. It could save you hundreds of dollars buying a new lamp when the projector may not be worth repairing.
Jun 04, 2008 | InFocus LP 820 Multimedia Projector
Removing the "lamp needs replacing" warning message
Hi guys
Firstly you need the remote to reset the lamp timer.
Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
Jul 31, 2007 | Sony VPL-EX1 Multimedia Projector
Rollei 66 Dual Slide Projector Logo
227 people viewed this question
Top Rollei Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Rollei Office Equipment and Supply Expert? Answer questions, earn points and help others
