Question about Mitsubishi WS-55809 55" Rear Projection Television
My Mitsubishi HD1080 series screen is coming inward from the top & bottom.. and occasionally red & green lines or black lines will flash through it... It started out just being inwards once in a while, but now it's just staying that longer and longer. (WS-55807)
  • sweetraver1 Nov 07, 2010
    Ugh boooo! It hasn't done the lines thing in like a week but I mean if it started doin it, it's just gonna do it again... Anyway yea I've been readin about the ICS probably needing replaces for now you can go to walmart for $400
  • Mitsubishi Master
  • 1,212 Answers
You have either bad convergence ICs or just bad grounds on the IC. I would go ahead and replace the ICs and check those small ohm resistors, as you have to pull the signal board out anyway. For futher instructions see the website www.TvRepairKits.com. They may have what you are looking for. Be sure you have the TV model number next to you. Thanks for asking and show a few hands of support!
Posted on Nov 07, 2010
Testimonial: "Yea for the cost of fixing it (hire someone since I'll definitely mess it up more lol) I could get a new flat screen at walmart :/ Thanks!"
  • Mitsubishi Master
  • 8,457 Answers
Ur tv is having a convergence issues problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv have 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced on the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Why does my tv have one blue, one red and one green line at the top of the screen but no picture?
The CRT inside the TV has gone bad. You can either find the make and model of the CRT and replace it, or get rid of the tv and buy another one.
Jun 08, 2012 | Televison & Video
Red and green
Replace both of your STK ICs they are big black ics will have part number on them STK392-570
Call Mats 1-800-628-1118 Parts are 10.95 each
Dec 30, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Nov 17, 2009 | Televison & Video
I have a 2005 Mitsubishi HD1080 big screen that today, when I turned it on, the power light comes on, flashes but the overall screen never come on. Turned & unplugged the power for awhile to see if...
Hello:
There is a problem within the digital board assembly. This is the metal can like unit to the left side of the unit when looking inside it with the back off. The power management is inside this unit. There are 7 1000uf 16 volt capacitors on this small power supply that needs to be replaced. The pwr board is the first you see after opening the Digital unit. Replaced the capacitors with 680uf 16v capacitors instead of 1000uf. After replacing the capacitors looking thru the holes in the digital assembly there will be a green flashing LED, Watch this light for a moment, should stop flashing and stay steadily green if all is normal. Also the power light will still flash for at least 60seconds then go off. Turn on power and happy viewing...Cost to repair this should range around $200-250.00 dollars.
Thk Please leave message...
Oct 07, 2009 | Televison & Video
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Green light, black screens, no sound, needs new battery???
The alarm is just a coincidence i suspect, green light comes on and stays on probably not the battery at fault. It would be red.
If the green light goes out and screens just flash one of your screens are at fault or a loose ribbon connection.
Jul 01, 2009 | Nintendo DS Lite Console
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi Projection TV HD1080
you need to replace your convergence ICs. Post your model number of your set, and I will post the correct stk numbers and a link where you can get new ones.
Apr 16, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
590 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
