Hitachi 53SDX01B 53" Rear Projection Television Logo
Posted on Nov 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have distorted picture issues. It's like seeing double.
matt martin
Level 3:
  • Hitachi Master 1,259 Answers
  • Posted on Nov 07, 2010
matt martin
Hitachi Master
Level 3:
Answers
1259
Questions
12
Helped
297452
Points
3635
I don't believe you need to see the eye doctor...yet! Your TV is on the fritz. You need to replace the convergence ICs and check those small ohm 1 watt resistors. You can get all the instructions you need on www.TvRepairKits.com. They will have original replacement parts for your TV. Thanks for asking and show a few hands of support!
What if my samsung tv has ghosting images/horizontal
thats a convergence issue I will need the model number of your samsung in order to assist further with the issue.
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Mirror or Misconvergance?
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
LVM-37w1 Westinghouse T.V. pictures goes nuts, is the the lcd converter board?
If you getting a lot of vertical lines, double picture, it can be the LCD panel driver board, or worst case will be the LCD panel, very expensive.
1helpful
Picture and lettering are double and wavy
the DPTV305 - DPTV345 convergence repair kit at the following link should repair that issue. The kit includes the replacement parts and a CD with detailed repair instructions.
http://www.tvrepairworld.com/
Hitachi hdtv ultravision digital projection tv. #53udx10b. Issue: Blue halo around the body of people.
my picture is distorted and showing double. The characters are orange and I can't read the menu items because they are also showing double.
Downloading to computer
Sounds like a Vista or Picasso problem. Suggest you use explorer to copy photos directly from camera to a folder on your computer, then look at them and see if they are OK, if so, it is a Picasso problem. If the same, is likely a Vista problem. If still in doubt. Take memory stick to a photo lab and load on their system and see what you get.
Distortion and double imaging
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Picture and color distortion
I am having the same problem hopefully some one answers us.
It's a Blue Convergence issue but how to fix it I am still waiting.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
