Question about Frigidaire GLGR104FS Dryer
Dryer was working and just quit is ther a reset button or something the model # is gler311a52
  • Rick Ead
    Rick Ead Nov 07, 2010
    Have you checked the door switch? if you take a jumper wire and disconnect the switch and jump or connect both those wires and it starts then you have a bad switch please message back with further results from this test the next step would be to check the timer and to see if there is a switch on the pulley to go to the motor i await your reply
    Thanks
    RIck
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 07, 2010
How do i make it quit beeping so often
Hello friend, thanks for your post!
I understand that your Frigidaire dryer is beeping and flashing lights. To reset your dryer you should disconnect power, by unplugging it or flipping the household circuit breaker, for roughly ten minutes. Which lights are blinking on your display panel? It could be providing you an error code.
If the reset does not help correct the issue, could you please provide me with your model number? Typically you can locate the serial tag (which lists your model number) on the door frame of your dryer. If you need further assistance please reconnect with me. -Matt
Sep 27, 2014 | Frigidaire Dryers
Lcd 42 inch tv
Try to unplug the powe cable from electric current for half or an hour then replug, Does ur tv have a reset button hidden somewhere? Press it , sometimes some machines need to push this button to restart working fine again Incase ther was a shortage or something. What's your brand name and model no.
May 15, 2012 | Tevion Televison & Video
Where is the reset button?
depending on the make/model,it will be the thermal fuse,some are resettable where others are a one time fuse and need replacing
Feb 12, 2012 | Dryers
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
heatman101
Jun 30, 2011 | Kenmore Dryers
Model LEB6000PQ0 has quit heating. What is best
your heating element has possibly burnt out. If you are proffecient in repairs this heater core is located in the bottom of the dryer casing. You will need to remove the backing of the dryer and look at either the left or right section at the bottom and you will see ther heater coil. Take model and serial number to an appliance parts house for replacement. If you need a repair and aren't able to do it yourself a appliance tech can do it for a minimal fee. It really shouldn't cost an arm and a leg to repair this
Hope this helped
Dave
Feb 10, 2010 | Dryers
Dryer quit working - will not do anything when "start" button is pressed
It would help to have the model number. the model number is on the front panel that the door shuts to. Have you checked your breaker? If your breaker is fine and you are getting power to the machine write back with your model number and I will try to help.
May 12, 2009 | Dryers
Asko 7005
Go reset your circuit breaker. Even if it didn't pop out, reset it.
Oct 25, 2008 | Dryers
HELP
GO TO SEARS .COM,CLICK ON PARTS,PUT THE MODEL NUMBER IN ALL YOU WILL GET ALL THE DIAGRAMS YOU NEED ,THANKS-MIKE
Jun 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer just quit
I would check to see if you have 220v to back of dryer where the cord mounts to dryer Check the door switch, , Take back off dryer There is a fuse in the back its white oblong 2 wires coming from it, left side on blower outlet ..be carefull hook the 2 wires togather and if it comes on the fuse is bad needs replacing same way with the door switch.
Aug 29, 2007 | Dryers
Frigidaire GLGR104FS Dryer Logo
37 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
