Question about Acer Aspire One Netbook 8.9" Notebook
My Acer Aspire One netbook shuts down at 38 seconds into booting up... I've timed it a dozen times and no matter I do or don't do (log in, etc) the screen goes balck and it shuts down at 38 seconds. I religiously run Iolo System Mechanic to clean & check my registry and I just ran a complete system scan prior to this problem starting. Any ideas???
  • mrkayak931 Nov 07, 2010
    what will tre-installing Windows do to all of the files
    Guru:
  • 846 Answers
The problem is because your software might have accidentally deleted system files... You can repair your windows using your setup windows disk....(Recommended) OR try starting your laptop in safe mode and try restoring........
Posted on Nov 07, 2010
    Even I try to start up in Safe Mode it only runs 38 seconds.
    As it's a netbook, there's no cd rom or Windows set-op disks...
  • Nitin Bhatt
    Nitin Bhatt Nov 07, 2010
    You can try installing windows from the USB drive.
    Follow the link below to download the softwarehttp://wintoflash.com/download/en/
    OR
    the easier way you can use a "External CD drive"
Why can't the automatic repair option fix my acer aspire v5 can't repair pc
I assume you are talking about startup repair which fails no matter how many times you run it.
The most common cause for this problem is file system issues on the hard drive. This usually occurs due to an improper shutdown (by holding the power button down to shut it off or if the AC is unplugged or fails without the battery installed or when the batter has failed completely). The solution to this is to either use a Windows boot disk (with an external USB DVD drive) and perform a CheckDisk on it or take the hard drive out of the computer and attach it to another Windows computer and perform a CheckDisk on it.
The second most common reason this occurs is due to a failing hard drive. Hopefully you have your data backed up somewhere. You will need a new 2.5" SATA hard drive and the Recovery Disk Set for your computer from Acer if this is the case.
I hope this has been helpful. Good luck and remember - always back up your stuff (pictures, music, documents, etc) - the more important your stuff is, the more places you want to have it.
Dave
Jun 12, 2014 | Acer Aspire One Netbook 8.9" Notebook
Shuts down on its own when using netbook
Possible dead battery, bad a/c adapter or processor.
Apr 16, 2014 | Acer Aspire One D257-13473 Netbook
Beep sound on booting pc
The beeping sound is a warning that the motherboard is running into trouble or there was a bad download. The easy way to find out is a system restore of your computer back before this became a issue, if you are lucky the settings will resolve the issue.
Apr 14, 2012 | Acer Aspire One PC Notebook
Shuts down immediatley after booting up
I can assume from your description and this "click" sound that you are facing an HDD problem. I would suggest downloading Hiren's BootCD from this link. Burn the content on a disk and boot up from it. Then start some of the HDD tests like HDD Regenerator and examine the results.I hope this helps!
Nov 20, 2011 | Acer Aspire One Netbook
My acer aspire one netbook will boot then shut completely down after a few seconds
Did u hit the netbook anywhere??? Check to see if its getting hot to the bottom where the cpu is, it could be that the clock(fan) is blocked with dust or isnt working properly and the shutting off is a safety feature to protect the pc from internal damages
Dec 08, 2010 | Acer Aspire One PC Notebook
My Acer One Netbook is about a year old. Yesterday is starting with this problem.... screen comes up saying F2 to set up or F12 to change boot process.... but then continues to boot up correctly, goes...
hope system got crashed.... Please install your laptop/pc by formating or by chaing you booting device option.... it you are booting with cd then change your option to CD drive as first booting device so that your system may work or you can install new OS..... to your PC/Laptop
Oct 22, 2010 | Acer Aspire One Netbook 8.9" Notebook
It won't finish booting up; it shows the windows xp logo then it flashes to a blue screen with writing on it and then it shuts down: it shuts down after a second so there isn't time to read what is on the...
You are probably heading for a reinstall of the os (or restore). You can try booting in safe mode (f8 after acer logo goes away, then arrow up on keyboard to safe mode (mouse wont work in this mode), then hit enter.
If this still doesnt work, check your manual on restoring your system.
Sep 25, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer d250 netbook restart problem,doesnt starts windows
To repair missing or corrupted system file/s, boot up with the Windows installation CD then –
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
Jul 12, 2010 | Acer Aspire One PC Notebook
Systems shut down
Sounds like a software error, Try using system restore to set back the pc to an earlier time. Also try starting up in safe mode and uninstall any software that you may have installed.
Sep 28, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one hibernates while idle
Go to your control panel in windows and go to the power options. In there you can adjust the amount of time it will sit idle til it hibernates.
Feb 16, 2009 | Acer Aspire 9300 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
