Question about Kitchen Ranges
Bissell all-rounder vacuum motor smells like burning and black exhaust marks on carpet.little use
    President:
  • 635 Answers
Your beater bar is stuck on some object and the belt is rotating against the surface of that same beater bar/brush assembly. This will leave black rubber dust on the carpet and eventually lead to a torn belt.
Turn the Vacuum upside down in an area where dust and dirt will be no problem to clean up. Make sure the Vacuum is unplugged before trying to rotate the beater bar/brush forward and backward to dislodge the foreign object.
Restart the vacuum on a friction free floor and verify that the beater bar is free spinning by dusting a non-carpeted floor with baby powder.
If you see swirl and brush marks as you draw back your vacuum cleaner should be ready to go. If not, you will need to follow your user manuals directions for replacing the belt.
Posted on Nov 07, 2010
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Bissell quickwash 1970E for carpets/hard floors won't come on
    If the burning smell was like rubber burning it is probably the belt. If you only used it a few times I suggest bringing it back to place of purchase. A belt should not go after just a few times of use. Besides if anything is burning after just a few uses I would return it.
    Mar 28, 2014 | Bissell Vacuums
    Hoover carpet cleaning started to smell like it's burning and black chunks of rubber came out
    Nan, there's obviously a belt that's shot and needs to be replaced. If it started to smell, then it was probably bound up at some point in it's travel path, that stops it from running and the motor shaft burns it's way through the belt, making the smell.
    Nov 03, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
    Bissell lift off bagless making high pitched noise, fan seems to run for 30 seconds after shutting off, and a burning rubber smell, is it the belt, and how easy are they to change
    The burning rubber smell is usually the belt. Be careful not to use it on your carpet as the rubber belt can get hot and liquify and really mess up your carpet (if you have one). Here's a link to some instructions for replacing the belt.
    http://www.ehow.com/how_4550054_replace-drive-belt-bissell-powerforce.html
    Mar 15, 2010 | Vacuums
    Last time I used my Bissell Pet Hair Remover vacuum it smelled like something was burning and it left a black mark on the carpet. What should I do?
    When you smell burning like that it usually indicates that the belt is worn and slipping on the motor shaft. You probably need to change the belt. You can get the belts for your model here:
    Bissell Pet Hair Eraser Belts
    Nov 11, 2009 | Bissell Upright Vacuum - The Pet Hair...
    My bissel 7901 won't spray water out of the bottom or hose to clean the carpet. I did smell a burning smell and shut it off. Is the pump gone?
    Depends, if the the smell was like rubber, then it may be the pump belt. If it is ok, then the pump could be bad, altho the pump wouldn't have had a burning smell. The main motor would if it was an electrical smell.
    Apr 14, 2008 | Vacuums
    Kitchen Ranges Logo
    184 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
