Question about Hitachi C15FB 15" Heavy Duty Miter Saw
Hitachi slide compound saw c10fsb the brushes are stuck I can not pull them out
2 Suggested Answers
SOURCE: C10FSB 10" Sliding Dual Compound Miter Saw: how to repair brake...
Replace the Stator!
Posted on Sep 14, 2010
Can't lock miter angle with slide handle
There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
Jun 24, 2015 | Hitachi C10FSB 10" Sliding Dual Compound...
Hitachi c12rsh brake
There are a few things that can cause this:
1) Check the brushes - make sure they are not severely worn and make sure they travel freely down the brush tube & contact the armature well.
2) If the brushes are OK the problem is most likely the switch. Tools with a brake have a 2 pole switch - one set will be normally open and one set will be normally closed (Most switches have a diagram printed on them) Disconnect the leads (keeping track of where you removed them) and using a continuity tester check the switch - you should get a reading between the normally closed contacts and lose it when you pull the trigger. Most likely you will find you are not getting a reading on the normally closed side and that would be your culprit. Hitachi C12RSH 12 Sliding Dual Compound Miter Saw Parts
Mar 16, 2015 | Hitachi C12RSH 12" Sliding Compound Miter...
Why will brushes not come out.
If the brushes are stuck on your Hitachi c10FSH miter saw after you remove the set screws with a allen wrench, what I did was pull on the spring it will eventually break off or the brush will come out. If the spring breaks get a small screw driver with a fine point and try to break the brushes up,tap lightly as you do not want to damage the armature below, then get a vacuum and suck the pieces out , pick out the remaining pieces until every piece of the old brush is removed. By spinning the motor and looking into the hole where the brush goes into you can see if all the pieces have been removed. What happened is that you waited too long before servicing the brushes and they wore flat and got stuck inside, otherwise they should come out easily.
May 08, 2014 | Hitachi C10FSH 10" Dual Bevel Slide...
I have the old model c10fsb mitre saw but need to replace the two parts of the handle & the trigger,where would i get them ?
You can go to www.toolpartsdirect.com and search by brand name than tool description by model number then view a schematic to get part numbers. You can also call direct at 1-866-597-3850.I hope this helps you. Good luck and thank you.
Mar 14, 2011 | Hitachi C10FSB 10" Sliding Dual Compound...
How do i remove (and replace) the carbon brushes on a hitachi c8fb2 moter saw? I removed the brush caps and can pull on the springs but not moving. DO i just pull harder? I'm afraid to break it in there.
After removing the black brush caps, take compressed air and blow any debris out. Next take a pair of needle nose pliers and gently pull the brush,,, ( you can use a moderate force). If it does not pull out you may need to remove the black vent cover adjacent and use a tiny screwdriver between the brush and the armature, as there may be a slight burr on the brush. Good Luck.
Dec 21, 2010 | Hitachi 8-1/2" Sliding Compound Miter Saw...
I borrowed a chop saw and it is in lock position, how do i release it
on the back of the saw where the arm goes up and down there is a pin that pushes in it will only stick out about a 1/2 inch.
Feb 23, 2010 | Hitachi C10FSB 10" Sliding Dual Compound...
Need wiring diagram for the box on the outside of the motor.
white from cord to B. grey from stator to A. blue from brush holder and red from switch to C!
Mar 25, 2009 | Hitachi C10FSB 10" Sliding Dual Compound...
Hitachi C15FB 15" Heavy Duty Miter Saw Logo
125 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
