Question about Plantronics Explorer 330 Headset
How do you turn off the bluetooth headset after you end a call? or does it beep forever unless the battery dies? I was given this headset and don't have the instructions. Thanks for your help.
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
See page 3 of user guide in a link below. The on/off button is called a call control button.
Plantronics Explorer 330 Bluetooth Headset Manual
Good luck from Headsets Direct!
Posted on Oct 13, 2011
Battery dies
replace them...nothing last forever..
Jan 08, 2014 | Skull Candy Skullcrushers Headset
Plantronics Voyager 500a bluetooth system. was using the lifter, but don't want to anymore, just want to be able to switch phone to headset mode and use the bluetooth. When I hook it up and hit the...
The beeps mean it needs to be repaired or resubscribed.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
If you are using a Cisco phone you could probably plug the headset base into the phone. If it is not you will still need your lifter.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Plantronics bluetooth will not turn on.
I'm wondering if the the battery has died in the headset. The battery is not replaceable but you can buy a replacement headset, follow link below.
http://www.headsetsdirect.com/84321-01-510-replacement-headset.html
Aug 18, 2011 | Plantronics - Bluetooth Headset Plus Base...
My Plantronics 665 Bluetooth headset went into a locked weird mode (no lights, no pairing, no turn off) The lights enabling feature is not working as it should. I doesn't turn off when keeping the...
Try letting the power on the headset deplete and then try recharging the headset. Not sure why you are having a problem with the headset not powering down, but that will generally take care of it. Sometimes if you don't turn off the phone it can lock the link between the phone and headset and in which case the headset will not turn off.
Everything I read on it indicates that the only way to reset it is to let the battery completely die, which takes up to 7 days if you have a full charge on it. Put it in a ziplock bag and put it in the freezer and the battery should drain overnight. Charge it back up and it should work fine again! If you try this, squeeze as much air out of the bag before closing, so there's as little moisture as possible.
Jul 01, 2011 | Plantronics In-The-Ear Discovery 665...
I have a problem with my S-69 bluetooth headset. It is not working. My cell phone can't find it and conect. Is possible that the problem is because the charge of battery is low?
it could be, try to re-pair it with your cell phone(turn both the phone and the headset off and then turn them back on then go thru the repairing process) . If it dosen't see it then try to charge it fully and repair it with your phone (same way again) . If that dosent work see if the phone can pair with anything else bluetooth. If it can then you might have just found the end of life of the headset (unfortunateley they don't last forever)
May 16, 2011 | Cell Phones
8xx plantronics blue tooth will not stop beeping after a call. i powered off the blue tooth and beeps stops but returns after the first call
This issue may be caused by the network and not a defective headset. Changing your phone settings as listed below will in most cases stop the frequent ringing/beeping in your headset while in standby mode. You may want to check with your service provider before changing the settings listed below, as the following activity may cause additional charges on your phone bill. If you can, remove and re-install the phone battery. This should reboot the phone. Go into the MENU > SETTINGS > ROAM. Change roam setting to "ROAMING ONLY". Users will no longer get any Bluetooth headset rings/beeps unless the phone is actually ringing for an incoming call. This is a temporary work around since once the phone is turned off, the roaming setting above is reset. You will need to follow these steps each time you turn on your phone.
Apr 23, 2011 | Plantronics Voyager 835 Bluetooth Headset
How do I unlock my backbeat headset. It won't turn on or off.
It sounds like a simple fix, let your battery die completely, after that you should be able to have it work again. You may have to re pair it to your phone but I don't think you will.
Dec 13, 2010 | Plantronics Backbeat 903 Bluetooth...
HBM 730 Bluetooth Headset Wireless Headset: Headset was given to me a while ago and I have a n...
To put your headset in paring mode, first turn it off. Then, press and hold the PWR/END button until the indicator led is solid lit (some 5 seconds). Now, make your phone's bluetooth software to search for devices. Select 'LG HBM-730' from the list. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
Hope it works for you
Hope it works for you.
Cheers! Carlos
May 05, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Plantronics Explorer  330 Headset Logo
47 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
